Question about Juniper Networks IDP Upgrade Kit for ISG 2000 system, including IDP Lic Key, additional memory, and 5-device NSM (NS-ISG-2000-IKT) Firewall
We dont have access to our juniper( ISG2000 ) using the consol cable ( username and password ) and we want to reset factory but when we enter the serial number its not working. is there any other solution that we can solve the problem?
Forgotten password for wifi network
Which operating system ??
Your wireless Internet password is the encrypted security pass phrase that was set up when you installed your wireless router.
Your router allows you to access the Internet.
If you have access to more than one wireless network, you may need to remember multiple passwords.
If you happen to forget one password, you have two options: reset your password or locate the current password.
Windows 7 allows you to view the security characters of all your wireless network passwords.
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
or
Reset My WiFi Password
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser.
Enter the default address of your router.
The default address is listed in your user manual or on the product website.
Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings. Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
How To Reset Your Router's Password
http://www.lostintechnology.com/how-to/how-to-reset-your-routers-password
Jan 06, 2014 | Computers & Internet
How do I recover a forgotten password for an overdrivepro63E wireless internet stick
Open your Web browser. Enter the default address of your router.
The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Nov 05, 2013 | Computers & Internet
I have a netgear router and im not connected
Log in to your NETGEAR router by browsing to http://www.routerlogin.net/ or http://www.routerlogin.com./ Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply. If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
Apr 09, 2013 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How do I reset my password?
Step 1:
Wireless networking is a common feature in homes and offices. Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network. If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu. Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings. Disable the wireless security. Reset to Factory Defaults Locate the reset button on your router. Typically the reset button is a small indented hole on the back of the device. Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings and add security as necessary.
Feb 27, 2013 | Computers & Internet
How do I recover the enable password on my Trapeze mobility exchange mx-8. Or how do I do a factory reset?
Hi Mate.
In case you still need to do this, or in case someone else stumbles on this problem and needs an answer, below is the the solution.
Connect to the MX device via console cable and recycle power.
Interrupt the boot process by pressing "q" followed by the "Enter" key when prompted.
at the boot> prompt enter the following command:
boot> boot OPT+=default (NOTE: This is case sensitive) and press "ENTER"
Presto, your devices boot with factory defaults.
Aug 28, 2012 | Juniper Trapeze Networks Mx-8 Wlc8r...
On a Marconi ES-1000 switch, how do I reset the username and password to factory defaults?
This is a switch!! so you need to conect with a console cable to the Switch and use Terminal or Putty to access the interface right!! Its like a cisco switch but if you dont remember the password and username it depends where it is exactly. If its the username and password for privilege mode or config mode!
On the Switch interface when you type "en" and press enter does it ask you for a password if NO then try this out
Type in: do show run or just show run and look in the list if you see any username and password and see if the password is in hash copy it and go on google and search for online hash decryptors.. You paste the Hash password and its going to give you the real password used!! Hope this helps
Jun 01, 2011 | Computers & Internet
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Recover Password
there are two ways ..try them
first :
In order to set a new password do the following:
Make sure you have a console connection to the Foundry device.
Reset the device using the reset button in front or remove and then reinsert the power cable.
Immediately enter b to go to the boot monitor mode at the time of boot up.
Enter no password in boot monitor mode.
Enter boot system flash primary (or secondary).
At the prompt enter the following commands:
FastIron>enable
FastIron# configure terminal
FastIron(config)# enable super-user-password test
FastIron(config)# write memory
Your new password is now "test".
second... only try if first doesnt work
Set the switch to its default configuration. Make a direct connection to the switch’s console port and power cycle the switch. Immediately after powering on, press <Ctrl><u> to access the system file menu. ]Select <D> to delete all user-defined configuration files. Press <Q> to boot the switch.
hope this solves your problem
Aug 08, 2009 | Foundry Networks Foundry EdgeIron 2402CF...
Client lost login/password, doesn't have copy of config either
No you cant, even if you reset the box it requires the default username and password. If you could brief me about your issues let me give you the solution
Apr 28, 2009 | Juniper Networks NetScreen 5GT...
Juniper Networks IDP Upgrade Kit for ISG 2000 system, including IDP Lic Key, additional memory, and 5-device NSM (NS-ISG-2000-IKT) Firewall Logo
95 people viewed this question
Top Juniper Networks Computers & Internet Experts
David Payne
David Payne
Are you a Juniper Networks Computer and Internet Expert? Answer questions, earn points and help others
