Question about Lincoln Ranger 250 Gxt Welder Generator K23824
I have a lincoln 250 gxt welder. It will not weld on DC. But it will weld on AC. It welded fine the last time i used it.
    New Friend:
    Problem Solver:
  • 9 Answers
Ask on weldingweb or miller welds, smokestack, they have a lot of good guys there.
Bryan
Posted on Oct 22, 2013
CarlGehrke
  • 169 Answers
SOURCE: lincoln ranger 250 voltage problem
Check the current control resistor with an ohm meter. The center terminal should have a smooth rise or fall of resistance when measured to one end or the other of the resistor. If the resistor and the wiring to it are OK, check the shunt in the output it'll be by the "electrode" terminal. If both are OK you probably have a bad control board.
Regards,
Carl
Posted on Feb 23, 2009
  • 81 Answers
SOURCE: I have a Lincoln 140 mig welder. It welds and cuts
Usually this is caused by a bad liner in the mig gun hose, or worn out guide rolls in the drive unit, or if this is not the case the speed of the wire might be set to high as this would force the wire into the weld causing the motor to heat up from resistance and shut it down on safty. Hope This Helps Don
Posted on Dec 02, 2009
  • 81 Answers
SOURCE: my welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
Posted on Apr 21, 2010
  • 60 Answers
SOURCE: my lincoln wire feed welder while welding,the weld
try changing the tip and make sure your ground connection is good on the steel and in the machine sometimes the ground wire in the machine comes loose
Posted on Nov 20, 2010
Testimonial: "thanks so much."
johnjnail
  • 1702 Answers
SOURCE: Hi I have a
check to see if the cooling fan is working. put a box fan behind the welder so it will blow threw the vents on the rear, or better yet remove the side cover and let the fan blow into the side of the welder.if this works replace the cooling can......GOOD LUCK
Posted on Jan 29, 2011
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding fine , then machine quit welding, would still rev up, but barely arch!
I had the same problem except it was with a miller welder. it was a bad ground connection on the ground cable. if you have an ohm meter. turn off your machine,but do not unplug it. check for resistance from chassis ground on machine to input ground if your input on the machine is good you may have a bad cable,input connection or the ground clamp may not be making a good connection to the cable. good luck!
Dec 21, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
HAVE A LINCOLN ARC 5000 WELDER MOTOR RUNS FINE BUT HAVE NO POWER TO WELD OR RUN ANY POWER EQUIPMENT
I know whats wrong licoln is a giant peice of **** i had this same thing happen to my ranger 8 look at your pc board 2 chips fell out ill bet on it
Oct 29, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
My welder has auxilary power, but will not weld
Blow air through cabinet to clean out the dust- low pressure. Check for continuity across the reactor. if you connect one test lead to the terminal "R4", should be a tape label on the connection. The other connection is "S1", you should see less than 10,000 ohms.
Check the weld polarity switch to make sure it is not damaged. If you have AC welding but no DC- check L1 the choke in series with the + connection on the bridge rectifiers.
Also check cable A4 that connects between the bridge rectifiers and the current selector switch. Make sureit is intact, and clean terminations.
Aug 23, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
Ranger welder does not generate enough dc current to weld with and only enough current to turn a ac drill very slowly. checked wires seem to be ok.
clean the brush rings with a very fine emery cloth is still then there is a controller board issue at that point it will have to go to a service center do to there are no supplier's for them other that Lincoln go to their sit HERE and find a service center in your area these boards range from $250.00 to $600.00 there is 4 of them in the machine they will have to remove the top and swap the boards till they find the right one have the same welder i have been through this with Lincoln already hope this helps
Aug 09, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
No or little ac output
By ac you mean receptacles, not ac welding?
If so what about welding output on AC (DC)?
If welding is OK then you may have breaker or fuse problem.
If welding output is also low or no output your problem is the generator.
You should check your gen rpm to be normal. If so you may have field problem: rectifier, AVR etc.
If you can measure the field DC voltage at rated rpm, if it is missing (very low) try to find any circuit broken.
If you do not succeed answer this instruction in order to give you more.
Jul 20, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Welding in TIG mode. Weld for 10 minutes, stop
the unit will need to go in for service there is a control bord issue there 4 in the unit these boards have to be tested by Lincoln i have the same welder and what they will do is swap out the boards till the bad one found if the unit is not under warranty they can be expensive mine coast 500.00 for the 1 control board there is not a clear way to say it is a particular one do to there all inter linked as to functions. go to the web site and search for a service center in your area hope this helps
Jul 02, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Lincoln Ranger 250 Gxt Welder Generator K23824 Logo
367 people viewed this question
Top Lincoln Welding Tools Experts
Jim Goldsmith
Jim Goldsmith
Rob Emerson
Rob Emerson
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
