Question about Intel D945GCL Motherboard
No display - Intel D945GCL Motherboard
    Novelist:
  • 153 Answers
Motherboards can have integrated video cards--however, if the integrated on-board goes out you can get a PCI, AVG, Express X1, Express X16 external card. $15 to $1000 or more.
I hope this helps.
Posted on Oct 21, 2013
Stop one mac screen from becoming multiple screens
Mirroring displays the same image on each display.
  1. Make sure your additional display is properly connected and powered on.
  2. From the Apple (?) menu, choose System Preferences.
  3. From the View menu, choose Displays.
  4. Click the Arrangement tab.
  5. Enable (check) "Mirror Displays" in the bottom-left corner.
In the example below. the blue boxes represent each display that is connected. The white bar at the top of both boxes represents your menu bar and is shown on both displays when they are showing the same information.
When mirroring, your Mac attempts to match the closest resolution between the primary (or built-in) and secondary displays.
The usable resolution is the closest matching resolution for both the primary and secondary display. If you choose a resolution that is not supported on both displays, OS X reverts to using the closest matching resolution.
Extended desktop With extended desktop, your displays are treated as one, continuous desktop.
  1. Make sure each display is properly connected and powered on.
  5. Disable (uncheck) "Mirror Displays".
In the Displays pane of System Preferences, each blue box represents a display that is currently connected. The size of each box is relative to the current resolution of the display it represents. In the example pictured below, the larger box on the left represents an Apple 27" Thunderbolt Display, while the smaller box on the right is the built-in display of a 13" MacBook Air (Color LCD).
The white bar at the top of the left blue box represents the menu bar you see at the top of your display. Menu bar placement determines which display is treated as the primary display in OS X. To change your primary display, click and drag the white bar from one blue box to another.
You can also drag any of the blue boxes to change a display's represented location. Use this feature to make sure the connected displays match their real world location when navigating your desktop.
As shown below, each display retains its maximum resolution setting as they are operating as individual displays showing a continuous desktop.
lion_choose_max_resolution_.pngPress Command-F1 to toggle between video mirroring and extended desktop
Press Command-F2 to detect displays
May 01, 2014 | Apple 24" iMac Desktop
Tip
Here is how to connect your Windows 7 installed notebook to an external display
Most of the notebooks that were manufactured in the past two-three years come with a HDMI port along with the old VGA port to connect your computer to an external display. Connecting and activating an external display on a Windows 7 machine is pretty simple.
Here is how to connect your Windows 7 installed notebook to an external display:
1. Connect your Windows 7 laptop to the external display using VGA or HDMI cable.
2. Then, switch on your Windows 7 laptop and also the external display.
3. Once Windows 7 is up and running, type Mobility Center in Start menu search area and hit enter to open the same.
4. If you have connected your Windows 7 machine to the external display properly, you should now see Display connected text under External display section of Windows Mobility Center. To use the connected external display, click Connect Display button. You should now see your Windows 7 desktop in the external display as well.
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays
on Jun 18, 2010 | Computers & Internet
Tip
How to connect Laptop to an External Monitor?
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays.
on Jun 14, 2010 | Computers & Internet
Samsung GT-e2152 Display white problem solution
Samsung E2152 display thik hai par graphics nahi aa raha hai. display white aa raha hai
Jan 23, 2012 | Samsung Cell Phones
I have a Marantz SR 8001. The front display lights went completely out, but the blue lights over the selector knob, volume knob, and the HDMI blue light comes on. I was setting up a Logitech 1100 remote...
You have a nice piece of Stereo...I believe you have mistakenly selected the" display mode OFF" function..,Here is the info that you can reactivate it..
If you need a soft User Manual here is the link for it too..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)...please insert some words in "
My Testimonials "
Hope this helps!
" display mode OFF"
You can select the display mode for the front display
of the SR7001.To select this mode, press the DISPLAY on the remote control or the front panel.When this button is pressed, the display mode is switched in the following sequence.Input Mode ? Surround Mode ? Auto display OFF ? Display OFF ? Normal Mode ? Input Mode Normal Mode: Displays the selected input function. If the function has been renamed using the Function Rename feature (see page 26), the renamed name appears on the display. Input Mode: Displays the input mode set via the Function Input Setup feature (see page 25). Surround Mode: Displays the status of the selected surround mode. Auto Display Off mode: The display is off. But, if you make a change to the unit such as the input or surround mode, the display will show that change, then go back to off after about 3 seconds. When changing the volume, it is not displayed. Display Off mode: The display is off completely. Note: • Only the DISP indicator will be illuminated on thefront display in display off condition
http://www.scribd.com/doc/53431794/Marantz-SR-8001-Owners-Manual
Jun 23, 2011 | Marantz SR8001
Hi i have an apple display connected to my macbook
Unplug the display from your macbook, and restart your macbook, when it's fully restarted and you are logged in, plug the display back in, then check to see if it is detected. Macbooks don't like to be put to sleep (shutting the lid) with a display connected, this causes issues with display detection. So always unplug your display and wait about 5 seconds before closing the lid on your macbook, and when you open the lid, wait another 5 seconds before plugging in your display. The only time it is acceptable to leave the display plugged in when you close the lid is when you plan to use the macbook in clamshell mode, this is done by plugging in and configuring your display, shutting the lid, and then "waking" the macbook from sleep mode with an external mouse (wired or wireless will work). That will start the macbook using the external display as the main display, without even turning on the macbook built-in display. Never connect or disconnect an external display when your macbook is off or in sleep mode. Have a nice day.
Jun 26, 2010 | Apple Cinema Display Flat Panel Monitor...
Menu display intermitent
display is disclosed which produces multiple visual displays in an intermittent manner which includes a display housing having a perimeter wall which is transparent during visual display and is an opaque mirror between visual displays. The perimeter wall of the display housing is a composite structure which preferably includes a transparent cylindrical substrate which is coated with an optical film and an opaque mask which defines display windows. Multiple visual displays are produced by a rotating display base which carries rows of rotating display elements. Preferably, the display elements are elongated triangular elements having three image faces which bear images which create the visual displays. The triangular display elements are arranged in a triangular configuration wherein the rows intersect one another at acute angles and are carried by the rotating base. The rotating base includes three display positions and each of the triangular elements includes three display positions. A stationary observer would see nine different visual displays and may see themselves mirrored in between and during the changes of visual displays. The perimeter wall of the display housing becomes transparent as the triangular display elements are backlit along their entire length by elongated fluorescent or neon light tubes. When the light tubes are off, the cylindrical display housing is an opaque mirror, preferably, about its entire periphery and height. Other embodiments of the invention include a single row of triangular display elements, and a rotating display base which includes display faces consisting of only a single display element.
Feb 25, 2008 | Solarism LM-1730 (Black) 17 in. Flat Panel...
Intel D945GCL Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
