Question about Kohler 14RES 14 Kw Generator
Loss of AC sensing for Kohler 14RES - Kohler 14RES 14 Kw Generator
    Problem Solver:
  • 12 Answers
Check for broken or eaten wires
Posted on Oct 23, 2013
WHAT DOES SENSE LOSS MEAN
RPM Sense loss means that the generator controller hasn't received a valid signal from the ignition coils for 3 seconds of attempting to start. Probably a dead or low battery or bad ignition coil. Replace the battery and try again. Call dealer if problem persist.
Aug 20, 2015 | Generac Power Systems Centurion by 16000...
Can I see a copy of order?
You need to request this from whomever you purchased the generator from.
May 31, 2015 | Kohler 14RESA Home Standby Air Cooled...
Loss of voltage, no communication between controller and voltage regulator
Can you see your controller or are you talking about on cue software.
Oct 21, 2013 | Kohler 14RES 14 Kw Generator
The display will not come on the generator. The battery is good
Check little 4amp breaker on top. If not you need new controller.
Sep 19, 2013 | Kohler 14RES 14 Kw Generator
First start up
Try disconencting the remote start wires between the transfer switch and the generator, if ot still does it you have a bad control board. If it stops, then check the transfer switch for correct wiring of utility and generator power wires, also check with an ohm meter if the run contacts in the transfer switch are closed, that would indicate loss of sensing, or bad board
Jul 19, 2013 | Kohler Electrical Supplies
Kohler 20kw RESA "invalid shutdown" fault
I have a Kohler 14Res and an error Invald Shutdown is indication and the engine is not crancking
Jan 30, 2013 | Kohler 20resa 20kw Home Emergency Backup...
Kohler 14 RES won't start
You need a couple of things / options. The carb heater base, and an oil heater (srews in the drain hole, and possibly a battery blanket at that temp. Some OEM's offer an adhesive strip that you can also stick to the bottom of the alternator, that is also 120V and warms the generator windings to keep moisture out
Not sure what country you ar ein but in the USA/CA they will be a 120V accessory and as such need utility power at the generator
Dec 31, 2012 | Kohler 14RES 14 Kw Generator
No 12v output from aux terminals on a vfx 3648
Pretty sure it won't provide current to start anything. Just provides 12vdc at a low current to pull a relay in.
Manual say it is auto reset on the aux terminals for the generator start relay. 0.7 amps max.
http://www.wholesalesolar.com/pdf.folder/inverter%20pdf%20folder/Outback_fx_vfx_installationManual.pdf
If you still don't have the voltage there at the correct time (when called for), you unit is bad or has a fuse they don't mention in the manual. Remember!! This is a called for function so the voltage will not be there all the time, just when required as per the programming.
Oct 26, 2012 | Wss Pre-Wired VFX3648 Outback Flexware...
Kohler generator drains battery while running and then shuts down with error code oc
The rpm sensing in the control module is missing or bad.
Answer these questions for more details:
  1. Does your generator output normal voltage?
  2. Is the starter turning after the Gen is running?
  3. Is the charging of the battery connected?
Jun 20, 2010 | Kohler Electrical Supplies
Kohler 14RES 14 Kw Generator Logo
286 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
