Question about Ovens
I have stanley comeragh cooker . smoke coming from the top . chimney and cooker cleaned. any solutions ?.
Stanley cooker trips when heating comes on. Clock not working
heater has the highst possiblity that causing the tripping of unit .check also before calling ur tech maybe ur MCB tipping due to evrload of
Feb 22, 2015 | Ovens
Hi I need a manual for the masport r5000 freestanding fire - can you help me
Al ways try Manufacture site . If not then go to eBay , type in your " Masport R5000 Free Standing Fire Manuel"
Oct 04, 2014 | Ovens
Fagor oven has error code F06
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Nov 28, 2012 | Fagor 5HA-196 X Single Oven
I'm looking for the service manual for a Rayburn solid fuel cooker
What do you need to know? They are so simple. Clean out space under hot plate now and again to prevent soot build up under the flue outlet space, have chimney swept now and again..(annually depending on use) .look in flap on bottom of flue pipe should tell you if needs sweeping.
Sep 06, 2010 | Ovens
Smoke comes out of grill on electric cooker
This sounds like some of the power wiring, or leads which go to the "electric" burners. the smoke is a wire based or very chemical based smell. that in it self is toxic. when it comes to something as major as this you should for your own safety contact the seller if it is under warranty. The voltages and risk or burns electrical and heat wise are not worth the risk to your person and or life and or property.
Nov 10, 2009 | Stoves 720EF Electric Double Oven
Cleaning above the grill element
I would not advise you to remove the element unless you feel competent to do so.
Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
you will not hurt anything by doing this.
Make sure you have the griil door open and your house door.
Plz rate my solution.
thanks.
Dec 18, 2008 | Candy FP855 Electric Single Oven
Oven smokes
If it smoke smells of burnt food or grease you have something on the surface of the element which is burning off.
If it is an acrid smoke it could be the element itself is on the way out or the fan (if it is a fan oven).
You need to make a visual check of the element/fan to ascertain their condition and clean or replace as necessary.
Nov 30, 2008 | Ovens
SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
to clean glass, just use scouring pads - glass is virtually impossible to scratch
Oct 01, 2008 | Smeg Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
