Question about Konica Minolta Office Equipment & Supplies
Magic color en1650 printer seems like the reader doesn't read the cartridges. Tried to buy new cartridges, change microchips and so on, but the screen says there is cartridge missing or out of toner. And I think the toner tube isn't spinning because if i wipe off the toner, it remains wiped off. What could it be???
  • 46 Answers
SOURCE: Dell 1600n has been ghosting lately
The 1600n AIO (all-in-one) is a laser printer. Laser printer use a statically charged "drum" to place toner on the paper. Your ghosting problem may be from the drum itself becoming too charged or simply dirty and not the cartridge. Servicing laser printers is tricky business because they use a lot of wattage/voltage to create the static charge and also "bake" the image onto the paper. A very quick fix would be to de-ionize the drum and clean it thoroughly.
First, make sure you have the unit completely unplugged for, at least, ten to fifteen minutes before proceeding to ensure that all static charge has had a chance to dissopate.
Second, remove the toner cartridge and place it on some newspaper or paper towels. Inspect it for any residual toner and/or damage that may be causing the ghosting (look for cracks/grooves/lines in the cartridge that shouldn't be there).
Third, take a used dryer sheet (or one that's had most of the chemical fabric softener rinsed off and then completely dried) and wipe the entire drum to completely remove any static charge. Then, using denatured alcohol and static-free, lint-free wipes clean the entire drum to remove any remaining detritus. Allow to dry thoroughly before proceeding.
Last, wipe the drum down, one final time, with a clean dryer sheet or lint-free cloth. Reassemble the unit and replace the toner cartridge.
Run a few clean sheets (blank prints or copies) to further remove any particles knocked loose and check for any more "ghosting."
Final printing will be necessary to check for inconsistencies or success.
Posted on Nov 08, 2007
bandana_gyrl
  • 181 Answers
SOURCE: HP PSC 1500 xi Cartridge Error Problem
You do need both cartridges installed in order to use the printer. Even if one is near empty it will print (although your quality may suffer).
Posted on Jan 17, 2009
Ajkill
  • 2035 Answers
SOURCE: Replaced new color cartridge and now printer will not print color
Try these steps if this fails then get the cart exchanged as Lexmark cart comes with 6 months warranty in it :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 29, 2009
Roop1980
  • 228 Answers
SOURCE: Color Cartridge Missing
Please follow the steps given below:
1 Turn the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Remove the print cartridges.
4 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
5 Repeat Step 4 for the other cartridge slot (if applicable).
6 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
7 Plug the printer/All-In-One back into the power outlet and turn it back on.
Next, try to perform a Self test:
1 Press the Copy button on the operator panel once (this button is located under Mode).
2 Press the Options button ten times until Maintenance appears on the display.
3 Press the left arrow button (-) once. The display should now read Self Test Page.
4 Press Select. The printer will print a hardware test page.
Posted on Apr 05, 2009
  • 159 Answers
SOURCE: Lexmark x7350 all-in-one printer says
Exchange the cartridge for another new Lexmark cartridge. I think Lexmark printers have gotten so finicky about kicking out refills that they sometimes reject original cartridges. I own a cartridge refilling store and I've had a couple original Lexmark cartridges returned because the printers didn't recognize them.
Posted on Dec 28, 2009
The printer marks an error with the color cartridge, i open it check it and still has ink, but still doesnt wanna print, what can i do? Its a lexmark x 2695
It could be that the color cartridge has gone bad now. Try to re-seat the color cartridge in the printer. And if that doesn't help, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Sep 11, 2011 | Lexmark X2600 InkJet Printer
Color ink cartridge cannot recognize in MP 198 CANNON PIXMA even i buy new original cartridge
That's fine, but it doesn't mean the contacts for reading the cartridge ID chip are clean. No, I don't know how they got dirty. Try a little EtOH and a Q-tip on the contacts, and of course try power cycling and resetting the printer until it comes to its senses.
Aug 06, 2011 | Office Equipment & Supplies
Just had the black ink cartridge refilled now canon mp190 says black ink cartridge is empty
Usually modern cartridges have a microchip that the printer reads in order to indicate how much ink is left and to fight against ink refilling. There are ways around it but your best bet would be to buy a brand new cartridge.
Mar 06, 2011 | Office Equipment & Supplies
Cartridges aren't working
Hi
It could be it's because you are putting the same cartridges back in again and the printer thinks that they are empty (they have little microchips).
What might work is to buy a new set of cartridges and use them (different microchips) then when they are empty try the ones you are trying to use now. - Although they still have the microchips the printer might think that because they have different chips to the cartridges you have just taken out that they are fresh ones. I don't think it remembers all the cartridges than have been through the machine.
Your English is fine - much better than lots who post here.
Feb 12, 2010 | Canon PIXMA iP1600 Printer
I refilled the ink of my printer, and when I'm about to use it, the printer keeps on alarming signifying that the printer is out of ink. well, in fact the ink cartridges were refilled already
depending on ur printer, some have a microchip on the cartridges and wen they are empty the micro chips knows and sends a signal to ur printer forcing u to buy new cartriges ,SNEAKY!!
Aug 30, 2009 | Office Equipment & Supplies
Epson do not recognizing new cartridges
Just posted this answer somewhere else...you probably touched the little green microchip on the cartridge. The oils in your hand prevent the printer from reading the cartridge. Hope this helps, sucks that you may have to buy a new cartridge though!
Aug 05, 2009 | Epson Stylus 1400 InkJet Photo Printer
Replaced toner but keeps saying replace supply using black only
This happens occasionally with after-market (refurbished) cartridges. Sometimes the people rebuilding the cartridges forget to replace the microchip on the cartridge that resets the copy counter. Most reputable re-manufacturers will send you a replacement cartridge if this happens.
It could also be a carousel alignment or sensor issue inside the printer - if this is the case you will have to call HP for service.
Whatever you do, make sure you do not try to manually rotate the carousel to change out the different cartridges - each time you want to change a specific color, close up the printer first and then press the carousel rotate button that's directly under the ready light, keep pressing until the display says that it's rotating to the color you want, then open and change that color, repeat for each additional color.
Oct 13, 2008 | HP LaserJet 2840 Printer
Toner Cartridge reads empty
did you change the microchip with the cartridge. also i believe that you can reset the levels in the menu
Aug 20, 2008 | Konica Minolta magicolor 5430 DL Laser...
Kodak 5300 color ink error
OK so i found some new information that should solve the problem. The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK CARTRIDGE2.gif EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error. So to fix your problem First Remove the ink cartridges and download and install the new Firmware. Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimburstment of some sort like a free set of ink tanks.
Jan 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
23 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
