Question about Audio Technica AT-PL120 Turntable
Audio-technica at-pl120 service manual - Audio Technica AT-PL120 Turntable
5 Suggested Answers
SOURCE: Distorted sounds
The AT-PL120 uses a magnetic cartridge to extract a music signal from the record. Magnetic cartridges all put out a very weak electric signal, and so their output must be strengthened, or amplified, to where it is as strong as the input from, say, a CD player. This amplification is provided by a pre-amp. If your receiver has dedicated "phono" inputs the pre-amp circuits are already in the receiver. If you do not have dedicated phono inputs you must either buy a pre-amp, or buy a magnetic cartridge turntable with a pre-amp built into itself. The AT-PL120 has a built in pre-amp. You can switch the AT-PL120's preamp on or off. The switch is located under the platter at the back side of the turntable. Take the platter mat off and turn one of the platter's holes to the back and you should see the switch through the hole. If you push the switch to LINE OUT the preamp is turned on and the turntable sends an amplified cartridge signal out the cables which MUST be connected to a receiver inout suitable for a CD player (a "high level" input). If you push the pre-amp selector switch to PHONO OUT the turntable sends the weak unstrengthened cartridge signal out the cables which MUST be connected to the receiver's dedicated PHONO inputs so the signal can be amplified with the receiver's own pre-amp circuits.
If everything is set wrong (i.e. LINE OUT (pre-amp on), and connected to phono inputs) you are applying two steps of strengthening to the turntable's signal which is too much. The resultant sound will be garbled. Try not to do this!
The other way to do everything wrong is set the pre-amp switch to PHONO OUT (pre-amp off) and connect the turntable's cables to a high level input. If this happens the turntable signal receives no amplification and the resultant sound will be thin and weak.
Posted on May 18, 2009
  • 189 Answers
SOURCE: brand new audio technica at-pl120
HELLO!
I don't know which country you are from, but if the mains plug has a fuse in it then replace it with the same type. If that does not do the trick take it back back where you bought it and get a refund or a replacement! There may well be an INTERNAL fuse inside the unit on the power supply unit which may be at fault. If it is under warranty don't open the turntable yourself - take it back - I WOULD!
All the best!
Posted on Jul 22, 2009
STYLUSCITY
  • 271 Answers
SOURCE: How do you replace the tone arm rest (plastic
Hi, there is a screw that fits up underneath the clip that needs to be undone to remove the tonearm rest clip. styluscity@gmail.com
Posted on Sep 13, 2010
Testimonial: "Good stuff. We'll give it a go. Later....got it thanks"
canwoodjc
  • 3301 Answers
SOURCE: I'm trying to figure out
All of Audio-Technica's phonograph cartridges employ the low-mass, high output moving magnet structure
Posted on Jun 14, 2011
Where can I purchase a replace tonearm locking clip for an Audio Technica AT-PL120?
Audio technica will send you a replacement clip free of charge. Just send their service department an email asking for one.
Feb 21, 2012 | Audio Technica AT-PL120 Turntable
I'm trying to figure out what type of cartridge the ATP-2 is which came with my Audio Technica AT-PL120 Turntable. Is it "Moving Magnet" or "Moving Coil" or something else?
These are the specs for your cartridge - it is of the moving magnet variety. Vector-Aligned Dual Magnet design and A-T's exclusive Paratoroidal signal generator. This unique signal-generating system is composed of a unified, laminated coil core wound with a single piece of wire. Internal mechanical and electrical connections are eliminated, minimizing magnetic losses and assuring better signal transfer. PCOCC wire
Cartridge Specifications (ATP-2)
Frequency Response 15-22,000 Hz
Channel Separation 23/17 (dB at 1 kHz/10 kHz)
Vertical Tracking Force 3.0 - 5.0 grams
Stylus Construction Bonded round shank
Output 5.3 mV at 1 kHz, 5 cm/sec
Channel Balance 1.5 dB
Stylus Shape 0.4 x 0.7 mil elliptical
Cantilever Alloy tube
Jun 14, 2011 | Audio Technica AT-PL120 Turntable
How do you replace the tone arm rest (plastic holder/lock) on a Audio Technica AT-PL120
Sep 13, 2010 | Audio Technica AT-PL120 Turntable
I'm a dj and I use the Auido Technica AT-PL120 as turntables. The problem is that when I mix, the pitch speed would increase and then eventually go down to the actual speed whithin seconds. I didn't have...
Before anything else I would clean the pitch slider control with a little bit of De-Oxit D5 cleaner or Servisol. It could be there is some dust/dirt in the slider control causing a fluctuation in speed because of bad contacts.
Spray a little in the slider, work it a few times and leave for about 5 minutes before trying. Hope this helps :)
Aug 26, 2010 | Audio Technica AT-PL120 Turntable
Brand new audio technica at-pl120 turntable not powering on; cant get turntable to spin
HELLO!
All the best!
Jul 12, 2009 | Audio Technica AT-PL120 Turntable
What do I need to hook up the AT-PL120 to an imac
I use Audacity. It's a 100% free sound editing software and works great for vinyl transfers...Linky
http://audacity.sourceforge.net/download/
Jun 16, 2008 | Audio Technica AT-PL120 Turntable
Audio-technica atp-2 cartridge with a atp-n2 stylus
Make sure the cart is connected properly, and check the manufacter's instruction with that cart. sometimes tonearm height and weights need to be adjusted for proper torque and sound.
Oct 26, 2007 | Audio Technica AT-PL120 Turntable
Missing Non-slip Mat
just search on ebay there about 4-5 pounds it would be alot easier as paypal is usable on ebay.
Oct 18, 2007 | Audio Technica AT-PL120 Turntable
Audio Technica AT-PL120 Turntable Logo
149 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
