Question about Smeg Ovens
Owen fan on but no heat - Smeg Ovens
  • 2,113 Answers
Many times if a double breaker trips an oven gets half of the needed voltage. The fan and controls only use 120 volts. Turn off the breaker and turn it back on again
Posted on Oct 21, 2013
Owen fan always run, after plug owen in. How to stop it or reset it?
Your Fan thermostat has failed, now the cooling fan will run forever trying to cool the broken part... Look for the thermostat in the wiring diagram that is with the oven, meter it for continuity, and if it fails, use the model number to order a new part from a local part store- your model number represents nothing here in America or I would tell you the part #! Range Stove Oven Thermostat 318578506
Jun 25, 2016 | Electrolux EOB6630 Ultrafan Electric...
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Gaggenau oven BO 270 error code E005
We have a Gaggenau BO250/251. It gave error code E005, and after a lot of frustration, we opened the left hand light (NOT the light at the top of the owen) and fiddled a little with the bulb. And voila, the owen worked again.
Stupid design to disable the owen when the light does not work. Bravo, Gaggenau....
May 19, 2012 | Gaggenau EB 270/271 Electric Single Oven
Double fan assisted oven, the fan is not working and no heat at all. Im assuming you dont get any heat at all if the fan is faulty? Can any one suggest any ideas?
Typically, the coils heat and the fan moves air/heat throughout the oven like Emergency Heat in a home furnace: 1st. check thermometer connections, 2. Look for reset button and reset...also, your electrical outlet, 3. make sure your coils are heating and if so look for faulty relays on your fan connections.
Feb 05, 2012 | Ovens
The oven has power but does not come on.
Your heating element may be bad .check with a ohm meter. or go to the appliance repair and purchace a new one. you also check oweners manual and see if there are any fuses that may have blown.
Dec 02, 2009 | Frigidaire Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Noisy fan once oven at temperature, this continues once oven switched off until it cools down. This noise has grown over the past few weeks and now sounds like someting is grating or inhibiting the fans...
copper rings (used as bearings) r out that is the problem od the air flo is jamed that is y is then owen fan owerheated....and copper is loose not tight anough
Jun 08, 2009 | Ovens
My turbo chef owen sense somtime 208vac and some time 240vac
Hello. If you take the right side panel off, unplug first please. at the back is a blower motor, two screws on the back vertical rail, and one at the front edge of where it is connected to blow, probably under the foil tape, this will remove the blower. On the back wall toward the bottom, under all the relays, is a voltage transformer that tells the controller which voltage you have, replace it, and problem will be corrected. If you are not comfortable with this, call Turbo Chef for a local servicer, and call them to repair.
As for the F6 EC error, you are having a temperature problem due to the control area overheating, there is a blower on the back, and vents on the front, and side, either these are clogged, the fan grid is clogged, and the interior has alot of dust coating the interior of the right side, please unplug, vacuum, and clean out the dust etc.., after reassembly, after about 30 minutes of operation, the blower on the back should be on, if not you need another.
Hope that helps, and thank you.
Mar 21, 2009 | TurboChef TORNADO Electric Oven
No heat from my oven Gaggenau EB 868_6
hi amy,
          it seems there is a defect in ur owen..because if light and fan works, it should heat, otherwise it means there is a fault in the heating element..so kindly cal any near by technician to sort out this problem or use our find oven repairman service to contact d near by repairman...
good luck
Jul 06, 2008 | Ovens
Kitchenaid Superba 27 built-in Microwave/Oven
Disconnect it from power outlet for 30 minutes to hard reset the owen. It may be a faulty control panel or the fan thermistore switch.
Apr 02, 2008 | KitchenAid 27 in. Built-in...
Ovens Logo
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
