Question about Kyocera Mita Km 4530 Copier / Printer
Show me types of toner for 4530 - Kyocera Mita Km 4530 Copier / Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
This machine takes TK-603 Toner
Posted on Oct 24, 2013
Its me again,after the user changed a new toner cartridge after few copies there is a dark back ground in copy.before replacing the toner the copy was perfect pls help me in this problem
Hi, After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
Pls tell me the life time of the developer powder and do I have to use only original toner
Hi, I have not come across any expiry date of toner/ developer and if it is stored properly in a cool dry place, away from sunlight an excessive heat, it works just fine. Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare. Genuine toner is always better in terms quality and yield. However, refill can work too.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine. As for Panasonic Workio DP-4530 and similar copiers, the toner comes in a bottle (which is only a container filled with toner powder) and the toner powder is pulled by the toner supply unit of the copier. I am using HP 9065MFP and refilling caused no issues. I usually refill it after proper servicing and use best available powder and it works absolutely fine.
I am getting this error code E03-60. Would you have an idea of what it may be? Thank you.
CHECK THE CHARGING CORONA.IT MAY BE DIRTY DUE TO TONER OR DEVELOPER DUMPING.CLEAN IT WITH SPIRIT OR ALCOHOL
Aug 01, 2011 | Panasonic Workio DP-4530 Copier
Tapping function of touch panel not working in acer 4530
you have to download acer manager it wil be to download on acer site for free under support/download and select on the next page type of laptop and so on it are availeble on the dutch acer site
Oct 28, 2009 | Acer Aspire 4530-5889 Notebook PC
Webcam doesn't work
you need the new installer from the acer web site and type www.acer.com download for laptop model and match windows with you.good luck
Aug 15, 2009 | Acer Aspire 4530-5889 Notebook PC
Web cam
Hi selamat_8832,
I think that the most likely problem here is the driver/software of the webcam, which is the acer crystal eye webcam. You should just uninstall the software from Add/Remove Program (Windows XP) or Programs and Features (Windows Vista).
Then afterwards, reinstall the software/drivers using the disc that came with your Acer laptop, it should contain the all the drivers for the laptop including the webcam. Just pick the correct driver to install. Now if you don't have the CD or is missing you can goto this link: http://www.acerpanam.com/flex/acer/bin/acer.html#app=2766&9e7c-selectedIndex=0&3386-selectedIndex=2&bca4-selectedIndex=1&bf37-selectedIndex=1&4f90-selectedIndex=1
When you open the page by default it should show the Drivers tab. Under the tab there are items you can choose from: Select Product Type, Select Product and Select Download. You first need to click on the "Select a Product Type" choose there Notebook. Then it will goto the next item which is "Select Product" choose there the model of your laptop which is an Aspire 4530. Then it will automatically goto the "Select Download" and it will show all the possible drivers you can download including the webcam drivers (acer crystal eye webcam) and they are labeled either for Windows XP or Windows Vista. So pick the one you need.
Hope this helps!
Peace! :)
Oct 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dp 4520 error code E03-60
error e03-60 means waste toner collection. could be a problem with the mechanism that delivers the toner to the waste bottle. looks arround there
Oct 09, 2008 | Panasonic Workio DP-4530 Copier
Printing to copier
ah, probably it means that the department ID is activated on your copier.
go to the printing preferences on of the panasonic dp-4530 on your pc, the click the job type tab.
on the space provided you may type in the code that you use during copying or ask the person incharge on your company re department code.
Aug 18, 2008 | Panasonic Workio DP-4530 Copier
System error
hi,
the c7100 error is a problem with the Auto Toner Sensor.
the first this to check is that you are using a genuine toner cartridge.
if you are please try to re-set the developer by keying in 1087 1087
then 130 press start and then start again once this is done please press stop twice, then 001 and start
if this does not fix it it may need either a new sensor or a new developer unit.
May 31, 2008 | Kyocera RI-4530 Black and White Copier
Kyocera Mita Km 4530 Copier / Printer Logo
55 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
