Question about Sharp AR-5516s
SHOW F2 40ERROR - Sharp AR-5516s
  • PATRICK
    PATRICK Oct 23, 2013
    the sharp printer is instal but the printing not coming out the systeme tell that is off line or technical probleme
  • Sharp Expert
  • 316 Answers
Replace the CRUM chip
Replace the toner cartridge
Posted on Oct 24, 2013
Is this show a remake?
Yes, it's based on the UK show of the same name: Shameless. The series is loosely based on the family life of the show's creator, Paul Abbott.
Sep 04, 2016 | Shameless (2011)
Tip
Unable to open .PPS attachments directly from Windows Mail in Windows Vista
To resolve the issue, follow these steps:
For .PPS files (Microsoft PowerPoint Slideshow)
· Click Start, type regedit.exe and press ENTER
· Navigate to the following branch:
HKEY_CLASSES_ROOT\PowerPointViewer.SlideShow.11\shell\Show
· Right-click Show and click Rename
· Type the word Open so that Show is replaced by Open command
· If you have PowerPoint Viewer 2007 installed, repeat the above steps in this key, as well:
HKEY_CLASSES_ROOT\PowerPointViewer.SlideShow.12\shell\Show
· After changing Show to Open, close Registry Editor window.
For .PPT files (Microsoft PowerPoint Presentation)
HKEY_CLASSES_ROOT\PowerPointViewer.Show.11\shell\Show
HKEY_CLASSES_ROOT\PowerPointViewer.Show.12\shell\Show
on Apr 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
On my intermatic HB88RC,I replaced the battery because it was dead and now it shows 44:44 on the display can this be reset?
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC is 7-day plug-in digital outdoor timer that uses AA battery installed on back of timer to power the display.
People write to fixya frequently report Intermatic timer stops working after replacing battery.
To check if your timer is still functional:
Press and hold clock button.
Press Day button until current day shows in display.
Press Hour until current hour shows in display
Press MIN until current minute show in display
Release clock button.
If current time shows in display, then timer is probably still good.
To set programs:
step 1) Press PROG button until 1 and ON show on display.
This is program1 ON.
Press day button until choice of days shows for program1 ON
Press hour until hour for program1 ON shows
Press MIN until minute for program1 ON shows.
step 2) Press PROG button until 1 and OFF show on display
This is program1 OFF.
Press day button until choice of days shows for program1 OFF
Press hour until hour for program1 OFF shows
Press MIN until minute for program1 OFF shows.
step 3) Press PROG button until 2 and ON show on display
Repeat steps above to set program2 thru program7
step 4) When programs are set, press CLOCK button to return to current time
step 5) add a comment for more help
Nov 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
Need some basic show command to troubleshoot
mode exec user Router)
ping ip
show ip route
show version
traceroute ip
mode exec priveligiado
show arp
show interface
show protcols
show ip protocols
show startup-config
erase startup-config
reload
Jul 27, 2010 | Cisco ASA 5520 Firewall
Deleting security code from Norstar Meridian M7208
Go to programming of Norstar bY Feature**266344 passwordwill be 266344.
Press show put the extension number then show the keep pressing next until display shows restrictions.Press show the next until dispaly shows ext rest. then show then show again and check what is the restriction filter number.
Press heading till u get restrictions.press show then show again. put the restriction filter code and delete or remove all restrictions from the filter and press release and come of the programming.
Restriction has been removed now.
After that u can easily make o/g calls without using any code.
May 05, 2009 | NorStar T7208 Corded Phone
The inbox shows I have new mail even though I don't.
in spam the message will shows wit the count so check it out
Apr 22, 2009 | Yahoo Mail
Percenteg Function problem in my Casio MJ - 120 Model Calculator
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
Mar 12, 2009 | Casio Office Equipment & Supplies
Sharp AR-5516s Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
