New monitor only shows my desktop image. and nothing else
At first it was all black and the power kept turning off. now it only shows my desktop image. it's a brand new viewsonic monitor vx2235 wm and it is connected to a dell inspiron 600m xp pro with a mobility radeon 9000 graphics card.
  • Anonymous Mar 13, 2014
    I have a Viewsonic VE710s which works well is I connect it to my laptop but it shows no image when conneceted to my old desktop. Connecting my desktop to an old SVGA works fine.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is not monitor problem as it is showing desktop. there is problem in setting of monitor or monitor Configuration is not proper. please refer manual which you must have received at the time of purchase.
Posted on Sep 30, 2007
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
I have a Samsung Sync Master 731BF and when I switch it on, the power light stays on but the image is black and wont show any picture whatsoever.
Hook a spare monitor to the computer to rule out the Video Graphics Card in the computer, if okay! It is the Samsung, "power supply issues" bad capacitors, sometimes show a bulge at top. But to be on the safe side replace the video cord from the computer to the monitor if possible.
Mar 31, 2012 | Samsung 731BF (Black) Monitor
Gateway one zx4351 screen does not turn on when i turn on the pc
I have to assume you get a power light on the monitor. If possible hook the monitor up to a different PC. If it works the problem is in the PC not the monitor. If not then the monitor is at fault. If the monitor see if there is an image on the screen by shining a flashlight on the face. If there is an image then the backlighting has failed. On desktop monitors it is usually the power board that lights the CCFL backlight lamps and it could be as simple as failed electrolytic capacitors that have swollen and failed. If so you could replace the capacitors or replace the whole power board. Of course most people opt to replace the monitor as a whole. If the monitor works fine then the video section is at fault. If it has a plugin video board then check to see if it's fully seated in the slot. If the video is integrated on the motherboard then motherboard replacement is needed.
Dec 08, 2011 | Gateway ZX4351-47 21.5-Inch All-in-One...
Tmy monitor shows the images only for 20 seconds, then it turns black.
Hi hope your monitor issue has resolved. I would suspect the problem is a hardware issue then a software setting. Since the monitor is over three and half years old, if your monitor is a LCD with CCFL back light and had been used almost every day, there may be 3 possible hardware issues. First is the internal power supply, that can go wrong due to heating problem within the monitor, this problem usually cause the monitor to display poor quality picture and may show interference lines on screen prior failure. Secondly, it may be the inverter that drives the back light, which may fail due to the safety circuit kicks in, because it involves with high voltages. Thirdly it may be the backlight itself, which is like most compact CCFL energy saving lamps that flickers or turn itself off when it reaches the end of its service life. This problem usually caused the monitor to show redness or yellowness images prior failure.
All of these can be resolved by qualified electronic repairers, all the best.
Nov 10, 2011 | Computers & Internet
My monitor turns on but it just goes out the power button it still active green like it is reading my conputer.but when it comes on and goes out its just black.nothing...
b24teddy, This seems to be a power supply problem. Some can be repaired (DIY) for $20 or less. $35 to $70 if contracting out the work. More if replacement circuit board is needed. From your problem description I get the feeling that your monitor "works" and will display an image or data on the screen. Your description of your monitor symptom is what is known as "black" screen or "black&blank" screen. If you know the pc has finished booting and is displaying the WIN-desktop, point a bright flashlight 1 inch from the black lcd panel and tell me if you see a faint image of your desktop. If nothing is seen=full shutdown of SMPS power supply. If icons are seen=partial shutdown only! If you read some of my older responses to owners of black screen lcd's in my FIXYA profile (pages 10 up) you will understand the problem and how some owners who are handy with a soldering pencil (iron) restore their units back to life. Yes, your's has a good chance of being fixed. Just spend an hour reading in my fixya file and then decide what you will do.
12fixlouie
Feb 06, 2010 | Acer Computers & Internet
No picture, monitor won't show anything black screen. Monitor was working fine put it on another computer and it won't show images. Could it be part of the power saving system? Is there a reset button?
Does the monitor show absolutely nothing, not even when first turned on? In that case maybe the cable could be defective or connected improperly, or the new computer might not be compatible (or set to output to, say, digital port, while you've got a SVGA monitor). In that case you'll need to connect a working monitor for the time required to reconfigure the computer.
If the image does appears at boot, or resetting the computer, and then disappears, it could be that the new computer is set to a resolution which is too high for the monitor, which goes in protection mode and effectively turns off. Again you'll have to gain access to the computer (maybe booting in Safe Mode) and lower its video resolution to something the monitor can handle.
Hope this helps, have a nice day
Jan 12, 2010 | Sharp LL T17A3-B 17" LCD Monitor
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
Screen goes blank
Screen going black would indicate a data flow problem- but then you would see a warning saying words to this affect or a back light/inverter problem. If by looking slightly sideways at the sreen you can see 'shadow images'[try a moving image to be syre] then you have a backlight /inverter problem If you see nothing at all ckecj the data cable pins- one or more may be bent
May 23, 2007 | LG L1910S (Silver) 19" LCD Monitor
Computers & Internet Logo
816 people viewed this question
David Payne
David Payne
