Question about Silver 26in X 14 0in 100 Percent Redneck Country Car Window Wall
What is 4 percent of 21000? - Silver 26in X 14 0in 100 Percent Redneck Country Car Window Wall
    Sergeant:
  • 330 Answers
810
Posted on Oct 21, 2013
What is the percentage rate of $18888.over 84 month period?
If the payments are $211.00 for 84 months and initial loan amount is $14,000 then the simple interest rate is 6.9560 percent.
Total of payments is $17,723.64 including interest of $3,723.64.
I don't where you came up with $18,888.
Nov 14, 2014 | 2014 Chevrolet Captiva Sport
Smith corona H 21000 series owner's manual
H 21000 IS A SMITH CORONA RIBBON NUMBER
Aug 30, 2014 | Office Equipment & Supplies
How do i port forward to a minecraft server to my wireless laptop easy?
For this example lets say the minecraft server is on local ip 192.168.0.5 and using port 21000, default is 25565, for its connection in the config file. If your laptop is in the same lan (network) you would run mine craft and connect enter a server ip of 192.168.0.5:21000 No port forwarding required. If you want to access this server from outside of your network you will need to setup a port forward for 21000 tcp to go to 192.168.0.5. You would also need to know your public IP. www.ipchicken.com or just google "what is my ip" So now armed with your public IP lets say 74.132.132.5 when you want to connect to your server on your local network you would open minecraft and type for the server address 74.132.132.5:21000. Your router will see that it is going to 21000 and it will check your port forward rules "Oh this goes to 192.168.0.5". Please note most home users have dynamic public IP's this means they can change so you would have to keep checking your public IP to give to people. You can sign up for what is called Dynamic DNS such as DynDns.com This will associate a free domain name you choose to always point to the correct public IP you currently have assigned at home.
Comment back if you have further questions.
Oct 25, 2011 | 2wire (2701HG-B) Wireless Router
Need btu rating ???
Carrier YCB213D Y Series Window Air Conditioner 21000 BTU 230/208V. No Remote Control. High-efficiency energy-saving units. Quiet cooling for living areas.
Please dont forget to rate ;o)
Aug 17, 2009 | Carrier YCB213D Air Conditioner
Loose rear wheel, believe it is the bearing. How do I repair it?
drum brakes you remove rear wheel- speed sensor-grease cap-flange nut-outer bearing-brake drum-inner grease seal-inner bearing-drive the bearing races out of the drum hub.to install -install the inner and outer bearing races.apply grease to the bearings and hub cavity.then you install the inner bearing -inner grease seal-brake drum-outer bearing-flange nut torque it to 159 to 192 ft lbs. THE REAR DISC BRAKE WHEEL BEARINGS-you have to remove rear wheel -wheel speed sensor-brake caliper and rotor-rear axle hub bolts-tone the wheel with tool 09445-21000-carrier assembly-nut after unstaking it-press out the rear axle hub-remove the bearing inner race with tool 09445-21000-remove the bushings from the carrier with tools 09453-33000b and 09545-21100.to install -press in the bushings to the carrier with tools 09453-33000b and 09545-21100- press in the bearings to the hub with tool 09221-21000.tighten the flange nut to meet the concave portion of the spindle-press in the tone wheel with tool 09221-21000-torque the nut to 191 ft lbs -install the hub and bearing assembly to the backing plate and torque the bolts to 88 ft lbs-install the brake caliper and rotor.install the wheel speed sensor if equipped.install the rear wheel.TO BUY THE TOOLS TO DO THE JOB.LOOK UP KENT MOORE TOOLS ON INTERNET.
May 30, 2009 | 1999 Hyundai Sonata
2007 jeep compass, 21000 miles, leased vehicle. speedometer and odometer stopped working, auto locks not working, em brake light on, brake is not, abs light on, 4wd light on
leased? take that thing back and dispute that it is not safe to drive. they need to do a complete check up on that vehicle. it could be as little as the the dash malfunctuning, to brake broken and 4wd broken. which idk how that would even be possible. at 21000 miles it may still be under warrenty and there is prob something writen into the lease about problems like this. please go to your dealer
Dec 15, 2008 | 2008 Jeep Compass
Big ban tree mathematics
Dear gaddar, this is relatively simply. You see if one customer pays 7000 then when someone brings three customers that mean he has given a company business of 21000. Company pays the customer who brought others 2000. Now if you minus 21000-2000 = 19000 is what company earns.
And when they pay out i'm sure they deduct certain amount for processing charges and service charges. Thats how these companies make profit.
If that has solved your problem please press 'fixya'
Nov 16, 2007 | Microsoft Excel for PC
Silver 26in X 14 0in 100 Percent Redneck Country Car Window Wall Logo
16 people viewed this question
Top Rad Dezigns Vehicle Parts & Accessories Experts
Lawrence Oravetz
Robert Rankin
Are you a Rad Dezigns Vehicle Part and Accessory Expert? Answer questions, earn points and help others
