Question about Myryad M Series MDP 500 7.1-Channel Amplifier
My myryad mdp500 preamp have a problem, few minutes after im turnning it on and it working perfectly somehow it turn off, maybe it is a protection problem or maybe its some electronic problem if someone could help me it will be divine! ty
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
Check for cold solder on the power supply board
Posted on Dec 30, 2013
2 Suggested Answers
  • 54 Answers
SOURCE: Pre-amp locks up
Check the repair dirctory at the bottom of this site
Posted on Dec 01, 2007
No out put on right channel
Check output transistors and drivers change emitter resistors
Dec 31, 2013 | Myryad Z Series Z160 Amplifier
Myryad ma120 power amp,loud pop when switched off
Sounds like a Electrolytic capacitor has failed. Search backwards from the speaker connections inside the unit to the main PC board. Replace the first ones that you come accross that are linked with the speakers.
Dec 15, 2012 | Myryad Z Series Z160 Amplifier
We have a Marantz sr4500, everytime we put it on it makes a Zzzzzz sound and then it turns off with a loud "buk" sound and shows protect on the amp's screen, after few seconds the amp turns...
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.In this case I think that some capacitors are faulty as when the set is put on it charges on to make the amplifier work. Possible fault in the protect circuit or preamp.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
May 11, 2011 | Marantz SR4500 Receiver
I have an Onkyo TS-DS939 receiver which worked for quit a while and then would not put out any sound when turned on. I would switch from TV to radio sources and after maybe 20 minutes it would start to...
Since the unit eventually works as expected, I would first look for poor solder connections inside the unit. It is quite possible that hte prolonged storage has damaged a few connections. If you can solder, try looking at the solder connections and resolder any that appear grainy or have rings. Update this if that does not resolve the problem and we'll look further.
Thanks,
Dan
Jun 12, 2010 | Onkyo Audio Players & Recorders
Lg chocolate 800 cell phone, I can turn it on but a few minutes later, the phone turns off by itself. Is it the battery or does it need reprogramming
The fault should be from the battery.
The few minutes when it turns on, does the phone work perfectly? If it works perfectly, then the fault is truly from the battery. But if it hangs or does not work properly, then maybe it needs reprogramming.
My advice is that, if you know a friend that uses the same phone with yours, borrow the battery and test it with your phone, as this would convince you if the fault is from the battery or not.
Best wishes.
Dec 22, 2009 | Televison & Video
Computer not recognizing video card maybe?
If you have a onboard graphics on your mobo they may have been turned on somehow I would check there and disable them if they have been.
Aug 15, 2009 | ASUS Extreme AX800XL Radeon X800XL, (256...
Turns on and works great...after about 10 minutes it doesnt work.
it is probably because your xbox is over heatng and you have a bad or loose wire in your xbox, try to put a fan facing the back of it before u turn it on
Jun 04, 2009 | Microsoft Xbox 360 Console
Myryad MI 120 Failure
This is a serious amp problem either relay has died doubtful,sounds like protection circuit is active due to a dc problem in board
Jan 05, 2009 | Myryad M Series MI 120 Amplifier
Myryad MA500 blown channel
Try the repair directory on this site
Nov 20, 2007 | Myryad M Series MA 500 Amplifier
Pre-amp locks up
May 26, 2007 | Myryad M Series MDP 500 7.1-Channel...
Myryad M Series MDP 500 7.1-Channel Amplifier Logo
109 people viewed this question
Top Myryad Audio Players & Recorders Experts
 Grubhead
Grubhead
Gary Dumers
Gary Dumers
Are you a Myryad Audio Player and Recorder Expert? Answer questions, earn points and help others
