Question about Car Audio & Video
Toyota 2007 hilux ute changed battery radio does not work
    Novelist:
  • 153 Answers
If you have an aftermarket radio there is probably a wire going directly to the battery and that wire has a fuse. These fuses are very sensitive. Fuse or Wire.
I hope this helps.
Posted on Oct 21, 2013
Toyota hilux vigo 2014 radio and power window not working after removing the battery
I gather that you put the battery back in? You need to check all the fuses and connections and also unhook one of the cables on the battery for a minute and then reconnect to make sure a surge did not lock something in the BCM up.
Aug 18, 2017 | Toyota Cars & Trucks
The fuel economy on the work ute toyota hilux 1997 is not any where what you would just call good. Can you please help me with things i can check or replace to mqke the fuel economy
well, you don't state when you last had it serviced???
1997 is a long time going without a tune up. so check/change the air filter, spark plugs, oil is a good start.
May 14, 2017 | Toyota Cars & Trucks
New battery - battery is drained in the morning.Replaced voltage regulator. Disconnected aircon. Still drains overnight. Ute will start and run with full battery but it drains overnight.
Easyest thing to do is pull one cable off your battery. Start pulling fuses and each time touch the cable to the battery post. When you find one that reduces the spark drastically that is the circuit to investigate.
Jan 06, 2017 | Toyota Cars & Trucks
I'm looking for cruise control for 06 B4000 Mazda
the best brand is commodore brand and they have a huge range to suit most every vehicle
I have one fitted to a toyota hilux and it is warranted as well as the vehicle itself It is a toyota recommended after market fit as the hilux (workmate ute) is not factory fitted with a cruise control
I self fitted the same brand to a mazda b2600 ute and it was faultless fir the time I had the vehicle
can be obtained from commodore on line or from off road shops
Aug 31, 2016 | Mazda Cars & Trucks
Where can i find my horn relay on my 2006 Toyota hilux
you have to register for these forums.
  • NewHilux.net • View topic - Horn relay www.newhilux.net/phpbb/viewtopic.php?t=10814
    • LAST UPDATED: 2014-08-26
    • 6 POSTS
    • FIRST POST: 2011-08-23
    NewHilux.net the Ultimate resource to the late model Toyota Hilux Ute ... Anyone know where the horn relay is ... When my horn died it was also clicking but the ...
  • horn relay?? - Hilux Surf Forum hiluxsurf.co.uk/showthread.php?t=74439
    • LAST UPDATED: 2012-01-31
    • 5 POSTS
    • FIRST POST: 2012-01-05
    guys im trying to fit a new more powerful horn i need to replace the relay does anyone know where ... FIRE UP THE HILUX ... Horn Relay Located Right hand side ...
  • Feb 05, 2016 | Toyota Cars & Trucks
    Toyota immobiliser
    When a battery is replace there is a possibility that certain elements of the CPU program become corrupted. Try using a scanner to reset the CPU program in the ECM to see if that turns on the immobiliser section.
    Oct 06, 2014 | 2006 Toyota Hilux 2.0
    1996 toyota hilux
    A rubber mallet is the trick, there is no tool. Even a stick of wood in a pinch. A soft blow or two should break the seal.
    Apr 18, 2014 | 1996 Toyota Hilux
    Need to know the tare weight of 1996 hilux LN106 double cab ute ? thanks
    Have a Toyota Hilux-LN106 model,need to know nett and gross weight for vehicle
    Aug 31, 2013 | Cars & Trucks
    Where is the fuse for the clock radio cig lighter in a toyota hilux 1993 model
    Made a short circuit here radio, cig lighter ,air Con ,clock, windows, indicators are not working but hazards are working it is a toyota hilux
    Oct 17, 2012 | 1986 Toyota Hilux 2200
    I bought am old toyota hilux ute 4door- speedo is 10km out so when you are doing 60km an hour the speedo reads 50km per hour, is there an adjustment on the rear of the instrument?
    first u have to chk weather the cable coming from transmition it fitted well or not if it ok u have to change cable it self
    regard
    Jun 21, 2011 | Toyota Pickup Cars & Trucks
    Car Audio & Video Logo
    77 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
