Question about Sharp Refrigerators
The compressor of my sharp ref. is running on and the off in a few seconds. on again in a minute or so and off again in a few seconds. sharp ref. model SJ-22T-H2G.
    Sergeant:
    Champion:
  • Sharp Expert
  • 243 Answers
Replaced Relay & Overload protector. after replacing same problem it could be compressor defective.
Posted on Jan 04, 2016
  • 65 Answers
SOURCE: fridge compressor problem ?
Seems to me you have a faulty cold control. (behind the temp control).Not too expensive , about 40 bucks.
Posted on Feb 24, 2008
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
woodchuck789
  • 4070 Answers
SOURCE: side by side not cooling
Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Posted on Jul 05, 2009
  • 1218 Answers
SOURCE: Refrigerator not cooling, compressor runs for 10 sec
Good day,
Either the start relay mounted on the compressor is hanging up and the protective overload is shutting the compressor down, or the compressor itself has an internal problem.
You can remove the relay from the compressor pins and take it to an appliance parts house for testing.
They will be happy to check it or you. If defective, replace. If it checks out O.K. then you have an internal problem with the compressor and it will take a qualified tech to sort it out.
Posted on Apr 02, 2010
  • 5469 Answers
SOURCE: how do change the
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
Posted on Feb 25, 2011
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Ref out of power.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 02, 2009 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Kichenaid refrig not keeping cold
Need to have someone with multimeter check the compressor and the capacitor. May be the start capacitor not allowing the compressor to run or continue running. Let me know, Sea Breeze
Mar 19, 2009 | KitchenAid Refrigerators
Unit stopped cooling
the click and hum your hearing is most likely the compressor trying to start. the most common problem is a bad start relay on the compressor. in rare cases the compressor may be bad. if you are mechanicly inclined youc an replace the relay yourself for less than 50 dollars. you will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company. good luck Peyton
Mar 11, 2009 | Refrigerators
Sharp split system, cutting out
If this is running in A/C mode, then I bet you have a low refrigerant charge. The compressor is dropping out on low suction pressure if it's cutting in and out every 5-10 minutes or so. If it takes hours, then it's likely a different problem.
Reply back and I can help you (been in that business for over 30 years.).
Feb 01, 2009 | Heating & Cooling
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
Fridge compressor problem ?
Feb 23, 2008 | Refrigerators
Thermal switch disfunction
How long did it work before quitting? how long did you have it turned off? Does the compressor run? Many things can cause this problem..Is the back wall of the freezer cold? Are all fans running? let me know....
Feb 15, 2008 | Refrigerators
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Refrigerators Logo
114 people viewed this question
Top Sharp Refrigerators Experts
geob91
Vernon Taylor
richie46
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
