Samsung 42 inch lcd tv...bunyi ada tp gmbar x da...tiba2 gelap..suara ok...apa yg rosak? Bape kos repair kerosakan
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 59 Answers
The what's it seems to be pushed, toggle the rosak, and reset it. You should be good to go!
Posted on Oct 21, 2013
4 Suggested Answers
relectronics
  • 38 Answers
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Posted on Apr 20, 2008
  • 289 Answers
SOURCE: samsung 42 inches not turning on?
hi..the reason to this problem is the power
supply.check whether there is any power
coming from the supply unit.
check it out..
thank u..
Posted on Feb 13, 2009
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
TV LED Polytron gambar hilang tapi suara ada, itu kenapa ya?
tv aku politron led 42 in tiba tiba layar nya hitam tapi suara nya ada.... minta solusi nya bang....
Jun 18, 2014 | Samsung LN32A330 32 in. LCD TV
Suara normal,gambar tidak ada
la32d400e1xxd suara normal gambar ga ada
Oct 16, 2013 | Samsung LN32A330 32 in. LCD TV
Glock password
ketika saya membuka aplikasi glock, tiba2 di minta passwordnya sama saya, dan yg anehnya hp saya tdk bisa keluar dri aplikasi tersebut, dan kalau saya matikan lalu saya hidupkan kembali hp saya mk aplikasi itu muncul kembali dlm keadaan meminta pasworrd. yg saya ingin tanykan apa bunyi password itu , terima kasih
May 14, 2012 | Cell Phones
Saya memiliki benq LCD seri q7T4. sekarang ini kondisi menyalanya harus menunggu agak lama untuk bisa menampilkan gambar. dan apabila sudah menyala, jika terkena warna warna gelap yang tampil layarnya...
Hi Mr. Kombat,
Kemungkinan capcitors ada yang rusak di circuit tv bapak. Tetapi disamping itu bisa juga backlight LCD. Harap di check benar benar kedua item ini. Masalahnya adalah pada salah satu item tersebut atau kedua duanya.
Regards, Jay
Apr 25, 2011 | Computers & Internet
Gambar tiba-tiba hilang saat tv on
hallo bagus,
Gambar hilang seperti apa ya?
1. kalau hilang suara ada, coba cek backlight nya dengan cara mengetuk panel .
jika di panel keluar cahaya (ditempat diketuk), itu tandanya backlight masih bagus, masalah berasal dari T-con atau pcb main.
jika diketuk tdk terlihat apapun, backlight rusak. Bisa rusak neon atau pcb inverter nya. klo neon rusak harus ganti 1 panel, tapi klo inverter rusak, bisa beli di service center.
2. kalau gelap dan tidak ada suara ; kemungkinan kerusakan dari power supply.
jika punya pengalaman di elektronika, coba ukur fuse dan kabel ac cord nya.
Semoga berhasil bro.
Mar 23, 2011 | Samsung LN32A330 32 in. LCD TV
Gambar tiba-tiba hilang saat tv on?
hallo bagus,
Knp saat saya sms tiba-tiba hp saya mati ??? truz sms yg say tulis hilang smua ,,,
menurut saya ada dua kemungkinan kenapa hp mati secara tiba2:
1. terjadi kerusakan firmware dalam arti hp anda terserang virus ato anda sering menginstal aplikasi yang tisak kompatible dengan hp anda
2. ada masalah dengan baterai anda...
coba bawa hp anda ke samsung center dan minta hp anda di upgrade, jika masih memiliki masalah yg sama berarti baterai anda yang mungkin bermasalah..
jika baterai anda menggembung (permukaan nya tidak datar), maka coba ganti dengan baterai yang lain..
kalau anda sedang menulis sms dan tiba tiba hp anda mati, pasti sms yang anda tulis hilang karena belum tersimpan dalam hp anda..
semoga membantu..
thanks. please rate
Mar 06, 2011 | Samsung Omnia Pro B7320 Smartphone
Saya mau tanya mslh bunyi "ngung" yg timbul pd saat dibuat jln...Lalu sama mekanik langganan katanya rumah kopling sama giginya yg sudah aus...Lalu gigi/gear sebelah rumah kopling dibalik (kata...
Hi, Disca96 untuk situasi ini saya sebut dealer lokal saya atau layanan / bagian departemen toko terkemuka dan menanyakan tentang kemungkinan perbaikan cepat, jawaban, atau bagian penyelidikan. Untuk informasi lebih lanjut tentang masalah Anda dan berharga "GRATIS" download yang Anda akan perlu klik pada link biru di bawah ini. Good luck dan memiliki hari yang indah. MMI Tech Tip Replacing Clutch Basket
How To Repair Grooved Cltuch Basket
Honda CB125S Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Mar 30, 2017 | 1976 Honda CB 100
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
