I need to know how to take the control panel off
  • 27 Answers
Probably got to remove the top cover first then have a looksee. turn off power first
Posted on Oct 21, 2013
Power Switch does not start machine when pushed, power receptacle tested okay.
Michael, May be a bad lid or door switch.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Diagnose Washing Machine Control and Program Problems
Washing Machine Will Not Start What To Check How To Fix
How To Know if Washing Machine Timer Is Bad
How to check if washing machine control panel is bad
Mar 11, 2016 | Washing Machines
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
The green botton plastic underneath it looks as it it broke off the button. It is not making contact with the print function
I would say that the Print switch on the control panel PCB has a broken solder joint. If you know how to get the control panel off and know how to use a solder iron, you can fix it. Or you will need to get a new control panel or you can call a local service rep. Good Luck...
Jul 02, 2010 | Canon PC-980 Color Copier
My xerox phaser 6300 control panel is blank and was working
Your control panel is bad and needs to be replaced, here is a video to show you how.
and here is the part (click here)
Mar 15, 2010 | Xerox Phaser 6300DN Laser Printer
The controls have locked and I do not know how to unlock
You may have inadvertently locked the control panel. Before assuming you have a malfunction, read the following: The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel. No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Aug 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Control panel locked
The following link explains how to correct a Control Lock problem for your washer:
I know this link is for Kenmore Elite and Whirlpool Duet. The newer model Maytags are manufactured by Whirlpool (which also makes the Kenmore Elite) so these instructions should apply. Keep in mind control panel options between models may differ slightly, but the locking feature instructions should be printed on the front panel. If you are not sure, there should be a tech sheet inside the washer behind the lower kick panel under the door. If not directly behind the panel, the sheet should be affixed to one of the interior cabinet walls.
If these preliminary measures do not correct the problem, you may have a more serious problem. If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: The Control Lock feature is a built in safety feature that allows you to lock the front panel to keep small children from manipulating the controls.
Aug 14, 2009 | Washing Machines
Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
Jun 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
Control panel
The control panel getting hot may be caused by the hindges on the oven door. I had my range serviced and when the door does not close all the way, then the hot air rises and basically cooks the control pad.
I just posted too with my frustration on this range.
Mar 29, 2008 | Amana ACS3350AS Gas Kitchen Range
Need new panel
the control panel,possible a bad component on it like a stuck switch ,remote p/u sensor
Mar 01, 2008 | RCA F36669 36" TV
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
