Question about Belling 335 Electric Kitchen Range
Cooker tripping fuse - Belling 335 Electric Kitchen Range
IS IT NORMAL FOR THE FUSE TO BLOW WHEN A HEATING ELEMENT DIES IN THE FAN HEATER IN MY ELECTRRLUX COOKER?
The heating element is shorting out and causing it to blow the fuse
Aug 25, 2014 | Ovens
Problem(s?) Bosch WFO2864GB/01
check the 13a fuse in the plug if you have a heater fault it may well have taken the fuse out as well as the rdc the machine will also need checking to resolve the issue rcd's are very sensitive with most having a trip current of only 30Ma although the heater is first thing to check
Mar 03, 2014 | Bosch Washing Machines
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Fuse keeps tripping have checked and removed the inner bulb but cooker still trips the fuse, Fan and elements appear to be working
insulation breakdown on fan element will need replacing when heats up tracking down to earth tripping your rcd.
Jan 07, 2010 | Neff B1421 Electric Single Oven
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Sep 13, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Fuse tripping
This usually means an earth fault, probably a faulty element
Aug 25, 2007 | New World 60ECHDGm Electric Kitchen Range
Belling 335 Electric Kitchen Range Logo
Top Belling Kitchen Ranges Experts
paulcarew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
