Question about Whirlpool Washing Machines
WFW9600TA01 Duet Whirlpool washer has a bad CCU, but I cant get the old one off? The front control needs to cone off and I don't see a way to remove it... Please Help
  • Whirlpool
    Whirlpool Oct 21, 2013
    Hi, Paul Elles. While we cannot assist with repair, we can offer links to our troubleshooting, use and care guides, replacement parts, parts lists, and service line should that be necessary. We hope this helps. Best regards, Ashley http://bit.ly/LrNZiS http://bit.ly/yLv4Z5
    Sergeant:
    Champion:
  • 257 Answers
  • 4 Answers
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Posted on Mar 24, 2009
  • 20 Answers
SOURCE: how to remove front kick panel on whirlpool duet washer
just pull out the bottom it will un hook,,
Posted on Sep 13, 2009
  • 7 Answers
SOURCE: NEW CCU for Whirlpool Washer
I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
Posted on Mar 11, 2010
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
  • 662 Answers
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Posted on May 19, 2010
F11 error - Whirlpool Duet washer
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2P3BOEFKI
you'll need to call someone in on this one,boards are very expensive and like it says it names both the ccu and mcu boards or the motor,if you call say whirlpool they might give you the part but you pay for labor and they will have the boards on the truck,the guy will replace one board at a time to see what one is bad,not like the older machines that you can check the parts with a meter.good luck
Mar 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer showing code F11?
The F11 code is a loss of communication between the CCU circuit board and the MCU circuit board. (CCU Central Control Unit, MCU Motor Control Unit) The most probable cause is bad solder joints on the CCU circuit board (also known as cold solder joints). This condition is also noted for causing a FdL code (door lock) The cure is to remove the CCU (inside machine, top, back, plastic case) remove the plastic case then the circuit board, it's easier that way. Then touch-up the large solder joints holding the spade connectors and the relays (5 of them). If you're not up on soldering techniques, you could take the CCU and this response to a good appliance repair shop and they should be able to help you out. Good luck.
Apr 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loading duet washer stops at the rinse/spin cycle door then locks. code F31 comes up. would this have something to do with the main board?
Hello
Error F31 in your whirlpool duet washer is displayed due to MCU (Motor Control Unit) failure. It is displayed if the heat sink gets too hot and then the MCU stops motor, then MCU sends the signal to CCU (Central control unit). Please check the wire connections between the CCU and MCU, if thats fine then check the motor operation. Hope you understand...replacing the part# that has gone bad is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Duet that is 2yr 2 month old the washer will not spin and give a F11 code. What do I do?
HELLO THERE
F/11 Serial Communication Error
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check MCU
  • Check CCU
  • Check Motor
Oct 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops beeps shows F 11
Hi
Thanks for using FixYa. Error F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). This usually occurs when CCU goes bad however, to check what has gone bad you’ll need to remove the top panel of the washer and also remove the rear panel to access the drive motor & MCU. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 error
Hi
Thanks
Rylee
Jun 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 14 error code on whirlpool duet washing maching. repair man say it needs ccu. How can I replace it and where can I purchase the part? Can this error code mean anything other than bad ccu?
Remove the bottom front panel 2-3 screws at the very bottom. Inside there should be a tech sheet that will explain error codes and how to trouble shoot them on your specific machine. Replacing the CCU is not that hard but getting to it is tricky. See following link to video on repairing duet http://www.rakerappliancerepair.com/ApplianceLibrary/Washers/WashersLibrary.aspx
Mar 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Older whirlpool duet washer has error F11
F11 is a serial communication error between the central control unit and the motor control unit.
Unplug the machine and open the panels.
Unplug and re-plug all wire connectors from the ccu to the mcu.
Inspect all wires and harnesses for a bad wire.
Could be bad components; ccu or mcu or motor
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer
F/11
Check Wire Harness connectors to the MCU, the motor, and-
Check MCU
Check CCU
Check Motor
Check Wire Harness
F/dL
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked.
It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch-
Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Feb 23, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
