Question about 821001/2100 2100 Security System
Avital 2100 alarm not working - 821001/2100 2100 Security System
Car wont crank over
check battery charged up ! check connections between battery and starter soilinoid and check the earth clean ! does the soilinoid make a click noise , if so replace it ! check main fuses !
Feb 05, 2014 | 821001/2100 2100 Security System
I need to know how to wire a led scanner to an avital 5303. The light has a red pos, black neg, and yellow that says brake. i want it to come on when the alarm is activated
Forget the yellow wire. Its for wiring WITHOUT an alarm. Connect the red to a fused 12 volt and the black to the orange "ground when armed" of the Avital 5303.
Jan 21, 2013 | AviStart 5303 2-Way Security / Remote...
Avital 2100 wont let me program 473 L remote
is the door open? door trigger switch has to be installed either green or violet wire the blue instant switch doesn't work as a valid trigger
May 10, 2012 | 821001/2100 2100 Security System
How can i bypass the kill switch? my car wont start now
car start some time, the kill switch will not let it start how can I take it off?
Aug 09, 2011 | 821001/2100 2100 Security System
Cranks but wont start
More information is required. What's the year/make/model of the vehicle? When does this take place, during remote start or with the key?
Sep 25, 2010 | 821001/2100 2100 Security System
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Alarm Light constantly lit
You are in valet mode. It means the vehicle will lock/unlock but not arm the security system.
Open the door then hit lock then unlock and lock. Led will now turn off and work as normal.
Apr 04, 2010 | 821001/2100 2100 Security System
821001/2100 2100 Security System Logo
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Colin Stickland
Colin Stickland
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
