Question about Gateway M Computers & Internet
Ge time control m460 g
My m460g it will stay on for ten min or so then shut off whats the dael
    Sergeant:
    Champion:
  • 212 Answers
Please changes battery
Posted on Oct 22, 2013
CGS980SEM1SS GE Cafe gas range which is 2 yrs 2 mths old. Oven shuts off after 5 mins, 10 mins, 20 mins...and at any temperature. All control panel functions cease to work, and most of the times the stove...
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1120 ohms then it should be replaced however, if it reads between 1080-1120 ohm then check the control and door switch and replace the part that is bad. You can also check the wire harness from the control to the electronic board. Hope this helps...
Daniel
Feb 11, 2011 | GE Cafe CGS980S Kitchen Range
My car starts up then runs for ten mins then dies. it will start up after that but wont stay running. then i come back an hour later then she starts right up and drives for ten mins then back to the same...
sounds like a bad cam sensor. have scanned if light on dash is on. if no scanner any auto parts store will scan for free. a bad or failing crank sensor will make vehicle stall out after a few seconds or minutes. if it is bad enough it will not start. because it controls timing.
Aug 19, 2010 | 1990 Mercury Topaz
My sunfire theft light stays on all the time. I can't start the darn thing, what do I need to do to start it. The bump and wait ten min isn't working
tery turning the key on for two minutes, than shut it off, than turn the key on for ten more minutes. This is suppose to work no promises.
Feb 10, 2010 | 1998 Pontiac Sunfire
Hello, My GE Dryer, Model M460-G timer won't shut off
Sounds like you have a faulty timer switch, check with your local supply house and get the same type of switch.
When you go to replace the timer switch, unplug the dryer, then remove one wire at a time. This will prevent wiring mix-ups.
Good luck,
I hope this helps
Oct 11, 2009 | GE Dryers
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
I have a goodman will lit run for 2 min and then go off
sounds like you have a bad control board or limit control
Apr 23, 2009 | Goodman GMS90703BXA Heater
GENERATOR WILL RUN ABOUT TEN MINS WITH LOAD THEN QUITS
You may have a 'TEST" mode on your Generator. Ten Minutes is usually the duration of the 'Exercise' function of most units, so I'd like to determine what mode you are starting your generator in. Please comment.
Mar 18, 2009 | Electronics - Others
GE A730 camera cuts off
Hi doctech:
Turn on the camera, then go to the menu and set the time to shut off to 5 or 10 min. These settings are usually set to 2 min. or less. This setting is to let the camera "go to sleep" or simply shut down to save battery power.
You can also try the following:
Go to the set up menu, find the RESET ALL and reset all the settings to factory.
Then go back to the setup menu and set the setting as you want them making sure to set the shut off time to more than 2 min.
Sep 27, 2008 | GE A730 Digital Camera
Shuts off after 20min
found cold connection on board at tuner
Feb 14, 2008 | Televison & Video
Computers & Internet Logo
35 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
