Can we measure the crt tv tube voltage and how?
  • 2,113 Answers
Let's just say it is over 10,000 to 50,000 volts. Don't go near the picture tube. Or anywhere else on the board without having a professional discharge tool. An if it has to be tested thenspecial high voltage testers or an oscilloscope (but only if the tv is plugged into an isolation transformer)
Posted on Oct 21, 2013
My crt tv no pics but good sound
In a crt television, you have a special power supply for the huge voltage for the tube. That can be defect, but also the heater in the back of the tube can be defect. Actually more defects can make the tube is not working, while the receiver and the audio part still work fine. Could be a little thing, like a bad soldering place on the mail board, but be aware it is dangerous to open a CRT, because of the very high voltages. (Up to 30.000 volt on the tube) and the voltage can be there on the tube and in capacitors.
Don't spend to much money for the TV, because the new flat panel TV's are not that expensive anymore.
Mar 27, 2015 | JVC AV-20220 TV
How to check filament in tv
If it has a picture tube first look with set on, three tiny filaments will be lit if good, not real bright as 6.3 volts ac voltage across two pins on the actual tube.
If you can see them lit they are ok---most sets mark them on the board at the end of the neck for the picture tube with H for heater.
Very carefully as high voltages on the board measure for 6.3 volts AC across those pins. If for example its 3 volts that is too low and the voltage from those pins can be physically traced back to the High voltage transformer creates it off two pins.
less than 12 connections between source and the board on the tube, if missing voltage at the tube follow it back--a single cracked or bad solder connection can cause this.
Dec 22, 2012 | Televison & Video
White screen with retrace lines
Hello
your TVs chroma IC has damaged. It has shorted circuits iniside, and you have to replace it with same type and number. If you have a good concept of soldering and desoldering, you can replace it. If you are not able to do so, leave it to any expecienced technician. Just open your TV, and measure the voltages at the three colur cathodes at the picture tube base board. If these voltages are very low, say at about 30VDC or so, measure the main input voltage to the video output section, and it should be around 260VDC or so. If it is not there this type of fault can occur. Measure this voltage first. If there is voltage as mentioned above, no doubt, the chroma Ic has damaged. OK.
Dec 11, 2010 | Sharp Televison & Video
Sony tv model # kv36fs320 no picture sound is there. Standby timer red light flashes 5 times.
The power seems ok as it was working fine this morning had kids channel on for my daughter for about 1-2 hours while I was pottering about cleaning then daughter told me TV had gone black
May 15, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
RCA HDTV HD52W59
Hello pac997man,
This may mean a few things. The Green CRT might be defective, the video signal to the green CRT might not be present, and the high voltage to the green CRT anode might not be active. So lets tackle the first possibility:
1) The Green CRT might be defective: You will need a CRT tester to check to see if the green tube is functioning, or you can measure the voltages on the pins of the CRT and use the schematic to compare them. If the tube is bad it will need to be replace (this usually requires that the other tubes be replaced also to maintain color balance)
2)  The video signal to the green CRT might not be present: This problem can be tested by measuring the video signal on the cathode of the green CRT and comparing it to the test signal on the schematic. This test also should be performed on the IC that controls the video input/output (oh yeah this means that you will have to have a signal generator to provide the proper test pattern, and a schematic to do this test)
3)  The high voltage to the green CRT anode might not be active: This test requires that you use a high voltage probe to measure the anode voltage of the CRT, if you have no voltage there this could indicate a problem in the HV Trippler. Since the other two CRTs are working the chance of the IHVT (Integrated High Voltage Transformer) being bad is very slim.
 By now you are wondering if I intend for you to try to do this yourself? The answer is : No I do not. What I would suggest is that you take the TV to a qualified TV repair shop or have them make a house call to troubleshoot and fix your YV.
I hope this helps
Thank you,
Shuttle83
Jul 24, 2008 | RCA HD52W59 HDTV Projection Television
Television cannoy be turned on
i think you have weak picture tube. when gun becomes faulty this happens. Measure Red -Green-Bluue cathode voltages. and filament voltage.if everything is perfect then the problem with your picture tube assembly. Contact service centre for further rectification
Dec 22, 2007 | Televison & Video
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
Arcing around neck board
sounds like bad crt if you saw arc inside glass...no economical fix-replace the monitor
May 30, 2007 | Likom ViewMate LP995 (White) 19 in.CRT...
Green s
check for bad solders on the crt socket . If it turns off again try running the tv with the crt socket off the tube but 1st try to time how it takes for the tv to turn off then disconnect the crt socket. If it does not turn off the tube may be bad, if it does not turn off check the voltages at the crt socket and see if all the voltages at the colour outputs are close to the same, if so then you have a bad tube when you connect the tube and the voltages change conciderably the tube is gone
Mar 08, 2007 | Toshiba 32A42 32" TV
Green is not being displayed on my TV
If you have experience troubleshooting solid state TV sets, you should be able to tell by a couple of voltage measurements if its a problem with the picture tube or the drive circuit. Simply take the multimeter and compare the base voltage of the green drive to the red or blue drive transistor. If the voltage is about the same, measure the collector of all three. if the green voltage on the collector is higher then the others, then theres an open between the drive transistor and the crt element. this could be an open resistor, a bad solder connection on the crt socket, or an open picture tube element. If theres no voltage there then your going to have to trouble shoot the drive circuit.
Sep 08, 2006 | Toshiba 32AF41 32" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
