Question about Kenmore 43042 Front Load Washer
Belt comes off
My belt keeps coming off my front loader, I keep putting it back on. Do I need a new belt?
  • 209 Answers
Maybe not, is the belt condition good, if so check for any wobble on the pulley, you may have worn drum bearings, this will cause the large pulley to wobble and throw the belt when it spins, also you can check the belt for being tight, it should be fairly tight but not tight enough to cause it to snap, if loose there should be adjustment at the motor end on the motor housing, all of this is assuming this is not a brand new belt, if so have you bought the right one?
Posted on Sep 27, 2007
Tensioner belt keeps slipping off front pully
Everett, Do you mean drive belt keeps coming off front pulley?
Possible causes, accumulated dirt/debris above deck or on trans axle, damage,stretched,wrong size belt, belt tensioner seized/missing spring if equipped, belt retainers/guides/keepers damaged /missing/ adjusted to far from pulley, damaged/worn pulleys, loose engine, belt way out of alignment,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Are the Causes of Belt Coming Off Riding Mower
Drive belt keeps coming off when shift into reverse
Need help with mower deck belt keeps coming off Craftsman LT2000...
belt keeps popping off
Jul 20, 2016 | Garden
Maytag washer
Hi the problem will be the belt has become streched dont keep trying to use the machine as this will cause the motor to fail usually it is the back of the machine that will need to come off once this is off you will see how the belt comes off it is really easy to do and most people who can use spanners can do this with no problem.
I would say it is the back that comes off the best thing to do is take the belt off and take it to repair shop so they can order you the correct belt.
Make sure you get the correct make and model number as their are several different belts for this make of washer.
Let me know if you need anymore help ill be glad to help
Dec 04, 2007 | Maytag MAV7600 Top Load Washer
Ariens Hydro ride on mower, Blade Drive Belt will not stay on Pulleys
Are you sure it is the right belt? Is the tightener working properly Are the pulleys miss aligned?
Nov 05, 2017 | Ariens Garden
FRIDGIDAIRE MODEL # FTF530FS0 - SERIAL # XC70213167 . BELT KEEPS COMING OFF?
(Start by this!)
I always recommend buying a replacement as belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person (assuming a front loader!):-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 12, 2011 | Washing Machines
1999 suzuki esteem glx 1.8 need diagram and instructions for replacing serpentine belt.
THE DIAGRAM IS ON THE HHOD ON UNDERSIDE OR ACCROSS THE FRONT TOP OF RADIATOR. THEIR IS A BELT TENSONER THAT LOOKS LIKE A ARM COMEING DOWN WITH A PULLY ON IT. PUT A SOCKET ON THE PULLY AND EITHER PUSH FORWAR OR PULL BACK AND IT WILL MOVE TO ALLOW THE NEW BELT TO GO ON. WHEN YOU LET GO IT KEEPS TENSON ON THE BELT.
Aug 03, 2011 | 2003 Suzuki Grand Vitara
Belt on the back of tub keeps coming off every time i put it on......why??
either the belt is not on the right set of grooves on the motor pulley or the belt is stretched and needs a new belt
May 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
The belt keeps on coming off i keep putting it back on but about 6/8 washes after it comes off whats wrong?
I suggest 1) a replacement belt and 2) follow my guidance notes on fitting ;-0)
These are pre-typed!
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
Hope this is your problem solved.
Good luck,
John C
Mar 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My washing machine keeps making a lot of noise when on spin and the belt keeps coming off.When we fit the belt back on the drum doesnt feel stable could this just be the belt please help
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to Applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you please rate my advice on fixya.
Nov 25, 2009 | Kenmore 43042 Front Load Washer
Belt installation
repacing the belt on a neptune is simple. unplug the unit and move it away from the wall.. now remove the 4 screws holding the access panel in place. loop the belt over the end of the motor shaft so that the grooved side of the belt catches the grooves on the shaft. now simply feed it around the tub pulley. if you find the belt keeps coming off you might have a bearing problem tht has caused the tub to shift. look for fine plastic powder, almost dust like, that would be the pulley eating into the back of the tub
Sep 04, 2007 | Maytag SAV5710 Top Load Washer
Kenmore 43042 Front Load Washer Logo
234 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
