Question about Vizio Televison & Video
My tv screen is black but I have a voice - Vizio Televison & Video
How to clear a square on tv screen that has a black rectangular block in middle of picture?
it could be you have pressed the old teletext service button, look for a button with 3 lines on it in a box and press it or try turning the tv off at the plug then back on again.
Jan 22, 2015 | Televison & Video
Black sreen
Sounds like possible backlight inverter problem. it could be similar to this one Sony 1 857 267 11 Backlight Inverter 13 56 Global flat screen TV parts... but need model number to be sure.
Feb 05, 2014 | Sony BRAVIA Televison & Video
Cant see picture but can hear voices
Look through the settings and see what has got changed, if you can see the menu. If you cannot, show a flashlight on the TV (only if this is LCD TV) from a distance and see whether you can see the picture. Try resorting to factory default settings.
Aug 16, 2012 | Samsung Televison & Video
Black screen
the problem is on the backlight of your LCD tv..it is a cold cathode lamp..with a power supply of 12- 24 vdc.the ballast of the cold cathode is deffective need a replacement...
May 17, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
The tv is in standby mode what do i do the tv comes on and stays on for about 2 mintues than the screen goes black and the voices are still there they stay on for about 30 seconds after screen goes black...
could be a problem with the lamp, ballast or power supply board. you really need a technician to troubleshoot this problem. call 1-800-samsung for nearest service center.
Nov 19, 2009 | Samsung - Projection TV replacement lamp...
Mitsubishi 5o in
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
