Question about Hasbro Playskool Kota and Pals Stompers - Triceratops
Kota triceratops head motor gears slipping - Hasbro Playskool Kota and Pals Stompers - Triceratops
How can I fix the tail of the playskool Kota triceratops?
If you can open Kota up (remove the fabric & unscrew whatever pieces),
you might be lucky enough to unjam it, or to move & re-align the gears.
There may be a spring that pushes one or both of the gears together that
may need to be checked too. If the gear teeth are OK but some other
part is broken, you can use 2-part epoxy from Walmart, Michaels, etc.
to fix it. Superglue will not work as it is too weak & brittle.
If the teeth on the gears are stripped, it will be tough. You can try rebuilding
the teeth with 2-part epoxy PUTTY (not glue) or 2-part plumbers putty from
Osh, Home Depot, or Michaels (Mighty Putty). and it may break again,
It might be easiest to call the company and ask about repairs and/or
replacement parts. Good luck!
Dec 01, 2016 | The Toys
How to fix my kota triceratops neck?
New you tube video 2:50 min video called Kota dinosaur
broken/hanging neck repair
Jan 16, 2016 | Hasbro Playskool Kota and Pals Stompers -...
How can I get an instruction manual for Playskool Kota dinosaur
Hasbro has the instructions and replacement parts for many of the Playskool toys on their support site, http://www.hasbro.com/site-map.cfm . The instructions for the Kota the Triceratops are available here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/61EED7975056900B10DED12F214D6B3E.pdf . The instructions for the Kota and Pals Ankylosaurus are here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/F235292B5056900B10B29E652C4640C1.pdf . However, they do not have any parts for the Kota and Pals set. You may find the leaf available in an internet auction.
I hope this helps.
May 01, 2014 | Hasbro Playskool Kota and Pals Monty T-rex...
My Kota Triceratops's neck is broken and she can not sing anymore. Still blinks, moves horns, wags tail and open and closes her mouth. No sound
The neck is not moving up it just stays down while he talks, blinks, and looks side to side;
any solutions?
May 03, 2011 | Toys
Need a user guide for kota
Dec 15, 2010 | Hasbro Playskool Kota and Pals Stompers -...
Can you get a replacement leaf for the big Kota
He can eat anything its not like the leaf has a magnet or anything if you put something in his mouth like your hand even, there is a little button/switch whatever on the roof of his mouth that causes him to eat
Jul 23, 2010 | Playskool Toys
I HAVE A MINN KOTA DECKHAND 35 THAT WONT WIND UP. IS THERE A GEAR I CAN REPLACE?
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Jun 09, 2009 | Boating
Hasbro Playskool Kota and Pals Stompers - Triceratops Logo
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
