Question about Nokia Classic 2700 Cell Phone
2700keypad butun problems
  • Nokia Expert
  • 2,973 Answers
Remove the front cover, lift the rubber keypad and blow hard into the phone front. It will remove the dust that got collected there. Or use your hair direr without heat ( if you put the heat on than you will burn the phone). Re-assemble the keypad and the front.
If this does not work then take it to a repair shop or the Service Center.
Posted on Oct 21, 2013
What is the problem to do not function q,e and start butun on my pc key boards?
Most of the time, cleaning the keys with compressed air and a soft cloth will do the trick. Mind you, removing the keys without breaking them can be a little tricky and press the key associated with the problem diagonally (lower left side of the button) for a couple of seconds...
Nov 11, 2016 | Computers & Internet
How to fix the error code for Ricoh 1232c sc517 and how to clear it
there's no error code like that
http://www.unitedtechsonline.citymax.com/page/page/4653767.htm
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER)
384-385:IMAGE DATA TRANSFER PROBLEM WHEN TANDEM IS USED(SBU,INTERFACE
BOARD,SICU,PRINT CONTROLLER)
390:TANDEM IMAGE DATA TRANSFER ERROR(NOISE,SICU,INTERFACE BOARD)
391-392:IMAGE STORAGE ADDRESS ERROR(SICU391-01)
395:CD-R/RW ERROR, INTERFACE BOARD ISSUES
397:CD ACCESS ERROR
398:CD-R/RW DATA ERROR
400:TRANSFER BIAS ROLLER ISSUES
401:TRANSFER ROLLER
430:QUENCHING LAMP ERROR
440:DRUM MOTOR LOCKED
441:DEVELOPER MOTOT LOCKED
491:LASER COOLING FAN LOCKED
495:TONER BOTTLE PROBLEM
496:TONER COLLECTOR BOTTLE PROBLEM
501:LIFT PROBLEMS FOR TRAY 1
502:LIFT PROBLEMS FOR TRAY 2
503:LIFT PROBLEMS FOR TRAY 3
504:LCT 1ST TRAY PICKUP OR LIFT PROBLEM
505:LCT 2ND TRAY PICKUP OR LIFT PROBLEM
506:LCT 3RD TRAY PICKUP OR LIFT PROBLEM
510:PAPER FEED MOTOR PROBLEMS
511:LCT MOTOR PROBLEM
515:TANDEM REAR FENCE MOTOR PROBLEM
520-521:DUPLEX JUGGER MOTOR PROBLEMS
531:FUSING DUPLEX MOTOR LOCKED
532:RELAY MOTOR LOCK
541:OPEN FUSER THERMISTOR
542:LOW FUSER TEMPERATURE
543:HIGH FUSER TEMPERATURE
544:HIGH FUSER TEMPERATURE
545:HIGH FUSER TEMPERATURE
546:LOW FUSER TEMPERATURE
547:ZERO CROSS PROBLEM
550:WEB EXPIRED
591:TONER SUPPLY MOTOR PROBLEMS
592:TONER BANK MOTOR PROBLEMS
601:SBICU TO SBU COMMUNICATION PROBLEMS
602:SBICU TO HARD DISK DRIVE BOARD COMMUNICATION PROBLEMS
620-622:SBICU TO ADF COMMUNICATION PROBLEMS
625-626:BCU TO FINISHER COMMUNICATION PROBLEMS
630:LINE ADOPTER TO CSS CENTER COMMUNICATION PROBLEMS
640-645:BCH TO SICU COMMUNICATION PROBLEMS
646:SICU PROBLEM
650-653:COUNTER ERROR JAPAN
701:ADF P/U ROLLER PROBLEMS
702:ADF FEED MOTOR PROBLEM
703:ADF TRANSPORT BELT MOTOR PROBLEM
704:ADF EXIT MOTOR PROBLEM
705:ADF ORIGINAL TABLE LIFT ISSUES
720:FINISHER LOWER TRANSPORT MOTOR ISSUES
722:FINISHER JOGGER MOTOR ISSUES
724:FINISHER STAPLER HAMMER PROBLEMS
725:FINISHER STACK EXIT MOTOR PROBLEMS
726:FINISHER SHIFT MOTOR PROBLEMS
727:FINISHER STAPLER ROTATION PROBLEMS
729:FINISHER PUNCH MOTOR PROBLEMS
730:FINISHER STAPLER MOTOR PROBLEMS
735:FINISHER PAPER STACK PLATE MOTOR PROBLEMS
736:FINISHER EXIT GUIDE MOTOR PROBLEMS
737:FINISHER FULL STAPLER HOPPER
738:FINISHER SHIFT TRAY LIFT MOTOR PROBLEMS
739:FINISHER FOLDER PLATE MOTOR ERROR
740:FINISHER FRONT SADDLE STITCH STAPLER MOTOR PROBLEMS
741:FINISHER REAR SADDLE STITCH STAPLER MOTOR PROBLEMS
742:FINISHER JOGGER SIDE FENCE MOTOR
750:COVER INTERPOSER BOTTOM PLATE MOTOR PROBLEMS
800:VIDEO OUT TRANSFER,CONTROLLER BOARD
804:VIDEO OUT TRANSFER,CONTROLLER BOARD
818:OPTIONAL BOARD,CONTROLLER BOARD, SYSTEM PROGRAM
819:BAD SOFTWARE
820:CONTROLLER BOARD OR SOFTWARE
821:CONTROLLER BOARD
822:HDD PROBLEM
823:NIB, CONTROLLER BOARD
824:CONTROLLER BOARD, NVRAM
825:NVRAM ERROR
826:NVRAM
827:CONTROLLER BOARD, RAM
828:SOFTWARE,ROM,CONTROLLER
829:RAM, CONTROLLER
835:CONTROLLER,CENTRONIC LOOPBACK CONNECTOR
836-837:FONT DEVICE
838:CONTROLLER BOARD
850:IP ADDRESS,CONTROLLER BOARD,NIB
851:1394 I/F CONNECTIONB,I/F INTERFACE,CONTROLLER BOARD
860-861:HDD
862:HDD BAD SECTORS
863:HDD
864:DATA TRANSFER ISSUES
865:HDD
900:NVRAM PROBLEM.ELECTRICAL COPY COUNTER
901:MECHANICAL COUNTER ISSUES
921:IMB, BICU FAILING
922:IMB, BICU FAILING
924:DRAM,BICU,IMB FAILING
925:BICU, IMB FAILING
926:BICU, IMB FAILING
951:F-GATE SIGNAL ERROR PROBLEMS
953:SCANNER IMAGE SETTING ERROR ISSUES
954:PRINTER IMAGE SETTING ERROR ISSUES
955:MEMORY SETTING ERROR ISSUES
964:PRINTER READY ERROR ISSUES
966:POLYGON MOTOR PROBLEM
970:SCANNER READY ERROR
980:HDD ACCESS ERROR
981:BICU, NVRAM
982:HDD CONSTRUCTION ERROR
984-987:HDD DATA TRANSFER ERROR
990:SOFTWARE PERFORMANCE ERROR
991:REBOOT SOFTWARE ERROR
997-998:DIMM, RAM ERROR
999:PROGRAM DOWNLOAD ERRORS
Oct 29, 2008 | Ricoh Office Equipment & Supplies
How to programe my TV what butun do you push to
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 07, 2014 | Televison & Video
I have level one wap1001 which i configured some time back and gave it an ip which for now i cant remember, will u please advice me on how to restore default ip so that i can be able to access it. Thanks.
There is no way you can find the find on the Access Point but you can reset it though.
There is a reet butun on the Access Point itself. All you need is to press that reset button for 20 secs and power cycle the device
Once AP is reset you can access it via default IP
Hope this help
Jul 04, 2011 | Levelone Level One FreeCon 802.11G Outdoor...
Having a problem with turning on a new BAII plus financial calculator. i presed the on/off butun but its not working at all.what can i do?
The first step is to replace the battery and see if that fixes the problem. If it doesn't, please reply to this post and we can go on from there.
Sep 21, 2010 | Texas Instruments BA II PLUS Financial...
Hi sir......i have minolta machine 1080......i want to cancel the mark of toner....how?...plz..
Minolta 1080
C000 Main drive problem C001 Main drive speed. Too fast or too slow C004C Fan motor problem C004E Power supply fan problem C0070 Toner motor drive problem C0071 Toner motor speed. Too fast or too slow C010 Drum motor drive problem C011 Drum motor speed. Too fast or too slow C0400 Exposure lamp does not turn on or AE sensor problem C0500 Low fuser temperature during warm-up C0510 Low fuser temperature after warm-up C0520 High fuser temperature C0600 Scan motor drive problem C0610 Lens motor drive problem C0620 Mirror motor drive problem C0990, C0991 Main tray up problem C0992, C0993 Main tray down problem C0994 Elevator motor problem C0996 Main tray shift problem C0998 Tray shift problem C0999 Tray shift return problem C099A, C099b Shift home problem C099c Shift drive motor C0b10 Auto exposure sensor problem C0b11 Paper clamp motor C0b30 Paper aligning motor C0b31 Paper aligning motor C0b50 Stapler motor C0b51 Stapler problem C0b52 Stapler sensor C0b60 Sorter bin motor C0b61-C0b64 Sorter bin movement C0d00 Duplex rail sensor sensor problems C0d20 Duplex home sensor C0d50 Duplex drive motor problem C0d51 Duplex drive motor speed C0F10 Auto exposure sensor problem C0F30 Paper aligning motor C4100 Exposure lamp stays on C0F79 Paper empty sensor problem
Sep 13, 2009 | Office Equipment & Supplies
Unable to print....
I got mine to work just fine after a few problems also. I hooked up the printer and let the computer find it by itself, then installed the software when the computer asked for the disk. Haven't had a problem since. ALSO, be aware that the Brother printers will NOT allow you to print ANYTHING if even ONE of the ink cartridges is out (which is ridiculous).
Mar 07, 2009 | Brother MFC-5440CN All-In-One InkJet...
Umax Astra 6700 download driver error code 129
here is your code mines
121:SCANNER HOME
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
Nokia Classic 2700 Cell Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
