Question about Beko Dishwashers
How to replace bottom door seal on beko DE2542FW dishwasher
  • keith dixon
    keith dixon Oct 23, 2013
    How to replace the bottom door seal on Beko Dishwasher Model No. DE2542FW
    Figued it out myself. Remove the front door metal panel Screws o inside of door (leave plastc control panel screws at the top alone).
    Take screw from front & rear of side panel out the lift them away from the bottom (Still attached to top). Accessing door tension spring / string. Remove the strings plastic hooks from hinges. (easer if you take tension by pulling string, underneth spring. If can't grip plasic hook, uses pliers to get hold of it), NB. THE DOOR WILL FALL LIKE A BRICK ONCE STRINGS OFF. Then Remove the door hinges frm door 2 Torx screws eith side of door (Inside). The door will fall BUT it is still teathered by cables so don't full too far. Replace old seal with new one (Before pulling out old one remember which way seals in slot), WATCH OUT FOR SHARPE METAL WORK). Then up hinges back on door, put door back on machine. Reconnect Draw string plastic hooks. Put back front of door & side panels. Then run a cycle to see if your handy work stopped leak. If not wait 2-3 weeks to get the other seal from TURKEY it seems that no one stocks them in the UK...
SOURCE: door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.0d084cc.jpg
Posted on Jul 02, 2009
SOURCE: dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
Posted on Aug 06, 2009
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Posted on Oct 14, 2009
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
SOURCE: I have a Kitchenaid KUDS25SHBL1
The bushings for the lower spray are are probably worn causing the lower spray arm to wobble. This sets up a wave pattern in the water at the bottom of the dishwasher and the waves cause the leak.
Posted on Dec 31, 2009
SOURCE: Miele G858 Icognito replace bottom door seal...how to remove door
Kelly --
Since you wrote your question 13 months ago, I'm guessing the problem is solved. Still, for others experiencing the same issue, here's my answer.
We also experienced leaking on our Miele 858 Incognito dishwasher and were able to replace the bottom door seal (today) without removing the door.
First, call the Miele Parts Dept @ 800-999-1360 to place an order for the door seal, which is part #3920725.
Remove the defective seal by loosening the four screws at the bottom of the door. Pull the black rubber seal out and discard. Install the new part in the same spot (underneath the green flange). Tighten the screws and you'll be in business.
Posted on May 08, 2010
Leaking beko dishwasher
The float valve could be sticking or defective.
Feb 03, 2018 | Beko Dishwashers
Dishwasher leak
leaks on washers are sometimes hard to find, so i'll tell you the two most common causes of washer leaks ive come across :
(1) DOOR SEALS these rubber seals don't last forever and if you use hard water to wash or heavy chlorinated they go fast , if you can pinch the rubber (hard) with your fingers and it doesn't relax back to normal in two seconds or less then yes its bad
(2) PUMP SEALS the water pumps are usually located in center of bottom of washer with a strong flashlight you see water dripping from center of unit (bottom) then chances are you have a bad pump seal
also i have found that using the new detergent packs of some brands cause pump seals to go as the plastic packs don't dissolve completely and get wrapped around pump shaft
Jan 18, 2016 | Beko Dishwashers
How do I adjust the door hinge tension on a Beko Dishwasher DW51
Hello!
most dishwashers have springs on each side of the door bottom that can be moved to different mount points to adjust tension.
In many cases they may be accessed by removing the bottom kick panel, but it may be necessary to back off the from adjuster legs, remove any other cabinet securing screws and pull the unit out slightly.
All the best.
Nov 20, 2014 | Beko Dishwashers
My beko de2542fw dishwasher is leaking from the bottom rite hand side of the door any advice would b great thanks
Might be a break in the drain hose. Mice maybe? We had this problem too, just replace the hose and all is well
Jul 25, 2014 | Dishwashers
How do I replace the rubber door seal on my beko wmb71642w?
This video will show you in detail how to replace the door seal gasket and fit the new one properly to beko wmb71642w washing machine How to Replace Beko washing Machine Door Seal
Oct 17, 2013 | Beko Genuine Washing Machine Door Gasket...
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
Beko dishwasher leaking
it will be helpful if you provide the model of the dishwasher. The door seal is most likely ruptured or cracked.
Jul 18, 2012 | Dishwashers
Beko door seal
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko WM5140W washing machine How to Replace Beko washing Machine Door Seal
Jun 27, 2012 | Beko WM5140W
How to remove door seal
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko Complete Door Wm1510w 2816000500 Wma10w Wm1510w washing machine How to Replace Beko washing Machine Door Seal
Apr 24, 2012 | Beko Complete Door Wm1510w 2816000500...
Kelly --
Apr 03, 2009 | Miele Incognito G858SCVi Built-in...
Dishwashers Logo
285 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
