Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
You wil need to connect using a DVI to HDMI cable. You can get one for about 5$ http://www.amazon.com/DVI-HDMI-Cable-6ft-Male-Male/dp/B0002CZHN6 Just connect it and choose the HDMI input its plugged into(1/2/3). If there is nothing on the screen adjust the display resolution on your computer. If you are using 1080i then the resolution should 1920x1080
Go to the following link, use the drop down tabs to select your specific motherboard product. From there it should give you a BIOS flash utility download under the "BIOS" section of the downloads. Hope this helps!
_
http://www.mercury-pc.com/downloads.php#
If you have the driver try to reinstall it. if you dont have it identified your mainborad model. (to identified your mainboar model click start>run and type "dxdiag" without quote.) look at sytem model and system manufacturer. find the driver on the net or post the driver model here.
