Question about Emerson MW8106W Microwave Oven
I have an older model Amana microwave Radarange mvh110E and wondering what are the watts? Can you help? Janie Staunton, VA societydame@verizon.net
    Top Expert:
  • Emerson Master
  • 12,223 Answers
See the definitions and how to calculate: God bless you
The Watt is a measure of power or how much energy is released per second. It can be shortened to W.
1 Watt can be written 1W.
We can calculate the power released in a bulb by multiplying the voltage in Volts across the bulb by the current in Amps flowing through the bulb (W = V x I).
Posted on Oct 21, 2013
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: amana micorwave
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
I have an older Amana Radarange Model RMC800E. It is apparently dead, however I opened up the box and found the thermostat on the magnetron to be open. I am trying to find a replacement part, but it has...
Hi Kevin,
Call a local appliance parts house. If you don't have one near by, call Appliance Factory Parts in Denver @ 303-761-1111. They should be able to cross that part for you... BTW...... good trouble shooting!!! PS, you might find that the blower motor is bad after all this..... check it first..... around 9 to 30 ohms??? I haven't metered one in years.....
Oct 09, 2013 | Amana Radarange Microwave Oven
Stopped heating
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Jul 17, 2010 | Amana LD10 1000 Watts Microwave Oven
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
I hit the lock button and it quit wrking
Hold down the "START" button for 5 seconds.
Jul 13, 2009 | Amana Radarange Microwave Oven
Help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
Mar 17, 2009 | Amana Radarange Microwave Oven
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
Nov 21, 2007 | Microwave Ovens
Emerson MW8106W Microwave Oven Logo
133 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
