Question about Kuppersbusch Ovens
Bulb for the oven in israel? - Kuppersbusch Ovens
Bottom oven lights keep burning out.
The oven bulb is different from an appliance bulb. The glass and base are specific for the high temperature application that is seen in a oven
The link from sears shows a sample of an oven bulb and the price represents the special characteristics.
I have seen where some bulbs are rated at 130 volts?
Range Oven Light Bulb Part Number 316538901 SAME DAY SHIP GUARANTEE from...
This link from Amazon relays some of the one star reviews of the appliance light used in the oven application. All ovens are maybe not equal where the heat may be more significant in one make over another.
Amazon com Customer Reviews GE Appliance 21188 40 Watt 415 Lumen A15 Light...
Another set of reviews that again show problems in some applications for bulb life.
40 Watt Incandescent A15 Clear Appliance Light Bulb 416768 The Home Depot
Not many reviews on this bulb. The 130 volt rating is an indicator of longer life? Of the choices I wood choose the following.
Sorry I couldn't help you more. Disappointing that no bulb stands out as the very best.
Bulbrite B40A15C 130V 40 Watt Incandescent A15 Appliance Bulb Clear Amazon...
Jan 09, 2016 | Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
What is the telephone number of De Dietrich support in Israel?
You can eother log a call with them on their customer service page:
http://www.dedietrich-heating.com/services/contact_our_customer_service
Or, the customer service rep in israel is:
Israel
MODCHEM Ltd. AGENCIES
Hararit - M.P. Misgav 20182
Israel
Phone +972-4-6782777
Fax +972-4-6782770
nachum@modchem.com
Jul 19, 2011 | De Dietrich DOC310 Electric Single Oven
I need some help please, The bulb has gone in my oven! how do I change this and where would I get a bulb? The oven is a candy and the model number is FPP403.
Most ovens use appliance bulbs that can be purchased at any home improvement store. Open oven and locate the glass protective cover and remove it. Remove bulb and replace w/new one, place protective cover back.
Apr 23, 2011 | Candy F248P Electric Single Oven
My oven light bulb keeps blowing on my Whirlpool oven.
becoz of some problem that might be your oven is on for long time
Apr 10, 2010 | Ovens
Replace oven light bulb? magic chef wall oven
for model 9815xub, the oven light consists of a light bulb cover(clear plastic, sometimes called lens) the light bulb receptacle( pressure mounted against the back wall of the oven ) and the light bulb, standard appliance bulb that screws into the receptacle, the same as the lens, it also screws into the receptacle, twist counter clockwise to remove both the lens and the bulb. as a reference try the following site:
www.partselect.com/ and type your model number in the window, then click on the oven cavity breakdown to view thwe assembly.
Jan 31, 2010 | Whirlpool RBS275PD Electric Single Oven
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Apr 27, 2008 | Neff U1661 Double circotherm super...
Ovens Logo
19 people viewed this question
Top Kuppersbusch Ovens Experts
ashburton
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Kuppersbusch Oven Expert? Answer questions, earn points and help others
