Question about Car Audio & Video
Wiring diagram for monsoon amp model 22674744
5 Suggested Answers
  • 45 Answers
SOURCE: cd wiring
On the 2005 Beetle, it's not in the trunk, but in the center console under the arm wrest. There is a special CD Changer that fits that spot that plugs directly into the plug under there. I've bought two off ebay for my wife's beetles and they work great!
Posted on Aug 28, 2008
michaelhi580
  • 62 Answers
SOURCE: 01 camaro stereo wiring diagram monsoon system
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Side Panels Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Posted on Mar 15, 2011
  • 29 Answers
SOURCE: 1997 grand prix 4 door radio wiring diagram
Go to your local dealership repair shop. They can scan a copy for you. It will make it all very easy when you have the wire colors and circuit description.
Posted on Jul 22, 2012
  • 14585 Answers
SOURCE: I need full complete wiring diagram for my 2001 Pontiac grand am gt Had a monsoon stock
Check the fuse first. Next replace the amp. It can be rewired at the amp. You need a volt /ohm meter to do it.
Posted on Feb 27, 2016
How do i get my monsoon car stereo working again amp model # 2264744
I assume this is the one you put into your car (I answered the other question) if the radio anti theft is on you would need to get a dealer to run the serial number of the unit and get you the codes....assuming the previous didn't change it. You might come out cheaper changing the radio out with an aftermarket unit. Any unit can be used with the factory monsoon system. (I have done this in my 04 grand am monsoon). All you need is the radio of your choice and an installation kit and wiring harness adapter. You do not need the GM integration harness as long as you don't care about losing the door chime, key in ignituon chine, etc. You will need to run a switched ignition wire for the new radio as the factory one uses a data wire instead. It's just a matter of running a wire to a fuse in the drivers fuse box that comes on with the key. It's a rather easy installation and if you chose to have it done professionally should cost about $50 for labor.
Nov 12, 2016 | Cars & Trucks
My JVC cd receiver model Kd R-310 reads protect on the display and won't work. I cut the wires to try to install it in my 2002 grand am. Can this be fixed?
Repair cost would exceed replacement cost. Try disconnecting all the speakers and see if it works then. Try reconnecting each speaker by itself and see if that causes the problem. Most grand am have the monsoon sound syatem...even if they aren't labeled as such. Pull the carpet in the trunk on the left (drivers) side wheel well. The monsoon amp is located over the wheel if you have a monsoon system. If you have to remove the amp then you must change the speakers out or rewire them as the monsoon system uses bi amp speakers. Most of the ga forums have extensive write ups on this system.
Oct 29, 2016 | JVC Car Audio & Video
Feb 27, 2016 | Pontiac Cars & Trucks
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
2001 VW pASSAT MONSOON SYSTEM BATTERY IS DRAINING?
In our car, the power wire is connected to a source that is only hot when the Key is in the ignition and turned to the Acc or On position. We have had no issues with the stereo draining the battery.
Jun 02, 2014 | Pioneer FH-X700BT
06 Pontiac g6 stereo has two different models a regular one and a monsoon hence two different wiring harnesses I have the regular harness and the monsoon stereo Is there a way to make it work the volu
if you can match the wiring funtions of each unit up one wire at a time.. then check before installing for operation..you have4 speakers (normally) a memory wire (on all the time for clock and stations) power wire(hot with key on) ground wire and antenna lead.. good luck..wire colors will not match but functions need to..(what each wire is for)
Dec 28, 2012 | Cars & Trucks
Jul 22, 2012 | Cars & Trucks
02 camaro factory wiring set up
Monsoon or no Monsoon. I have the wiring diagram for a 2002 Camaro with no Monsoon system.
May 26, 2010 | 2002 Chevrolet Camaro
Radio Wiring Diagram
Go to www.crutchfield.com.
On the bottom of the page there is a link for product support. On the next page, type "2005 Grand Prix" in the search box and hit enter. The top link shows an image and pinout on models with Monsoon sound systems, the second link for ones without.
Hope that helps! Good luck!
Jun 13, 2008 | 2005 Pontiac Grand Prix
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
