Question about Compaq Presario 700 470024-192 Notebook
I couldn't operate touch pad buttons - Compaq Presario 700 470024-192 Notebook
    Problem Solver:
  • 19 Answers
Plug the external devices to assist you
Posted on Oct 21, 2013
  • 48 Answers
Hi
update your windows , or reinstall windows repair
Posted on Dec 19, 2013
My compaq 621 laptop was not working for touchpad .
Usually, your laptops have a button that ought to turn you touch pad on or off. Check that it is not turned off. If it is turned off, then try turning it back on.But if all is ok, then perhaps the drivers for your touch pad, that supports your operating system is not installed. Try installing the driver that suits both your system brand, and the operating system.
I hope this was helpful?
Apr 19, 2011 | Computers & Internet
Touch pad has frozen/turned off for no reason. Any ideas why?
You have probably accidentally typed in shortcut for turning off touch pad. Look for function button (FN) and press and hold it, then find touchpad button ON/OFF, usually some of F-buttons has icon above it.
Mar 07, 2011 | Samsung NC10-14GW PC Notebook
HP Dv4 TouchPad buttons not working
hello
try to check the button above the your touch pad there is a locked and unlocked button, red light is locked, blue light is unlocked. and if your touch pad button is unlocked. if still not working try to check your o.s or third party software.
thanks
Mar 03, 2011 | Computers & Internet
I have new ProBook 4720s and the touch pad is locked? How do I unlock it?
You will have a push button just above the touch pad, if you push that button it will activate the touch pad...
Alternatively you will have the touch pad symbol printed on one of the function keys (f1 to f12), if you presss the "fn" and corresponding function key it will activate the touch pad...
Feb 06, 2011 | HP Computers & Internet
Once a mouse was attached the Acer Aspire 5532 touch-pad no longer works. When the mouse is disconnected the touch-pad still will not work. I do not see a toggle button to use to toggle between the mouse...
HI Diane,
Since you haven't provided the Windows Operating System version (XP/Vista/7 or other?), I'll have to provide the general scope of what you should try.
1. Go to the Control Panel and open up your Mouse section
2. Look through the different tabs until you find an option to either "Enable" your touchpad, or one that says the equivalent of "Disable Touchpad when external mouse or device is connected"
The idea is to accomplish your aim by working with the mouse settings provided for your system. Good luck and go easy on the "blue thumb". Please provide more specific information before a negative response.
Thanks
Aug 29, 2010 | Acer Aspire 4520-5582 Notebook
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
Disable touch pad
at the top of the touch pad you can find the small button just press that button and the laptop touch pad was disable
Feb 26, 2010 | Mirus SITA536V Notebook
Touch pad
Chek the color of the light attached above the Touch-pad.
That must be Yellow.
Click the button just by the side of the touch-Pad.
It will be green. You should be able to use the Touch-pad then.
May 12, 2008 | Microsoft Windows Vista Ultimate Edition
Monogram wall oven F9 error
“F— AND A NUMBER • You have a function error code. Press the CLEAR/OFF pad. Allow the OR LETTER” FLASH oven to cool for one hour. Put the oven back into operation. IN THE LOWER OVEN • If the function code repeats, disconnect all power to the oven for at DISPLAY least 30 seconds and then reconnect power. If the function error code repeats, call for service Here is someone that had the exact same problem: intermittent F7 error code. I couldn't even get it to do the F7 error . There's a pretty good tech service sheet inside the control panel. I followed its procedure for testing the keypad (which was nothing more than pressing all the buttons and hearing it go "BEEP!" silly.gif). But the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved! It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here. **** this helps. :]
Dec 14, 2007 | GE Monogram ZET3058SHSS Stainless Steel...
Compaq Presario 700 470024-192 Notebook Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
