Question about Black & Decker Garden
Need manual for b and d hedge trimmer gt230 50cm
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
  • 246 Answers
SOURCE: I need a manual for a homelite gas hedge trimmer
Hello cosorio70:
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
rogrrabbit
  • 986 Answers
SOURCE: Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Posted on Jun 17, 2009
SOURCE: Looking for owners Manual for Echo HC 1500 Hedge
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
Posted on Jul 27, 2009
How do I put the blade back
Husqvarna Hedge Trimmers 122HD60
www.husqvarna.com/.../hedge-trimmers/122hd60/966...
Husqvarna GroupHusqvarna 122HD60 is a low noised and light weight hedge trimmer for domestic ... 23 inch. Weight. 10.8 lbs. Add to wish list Find a dealer near you. Manuals.
Oct 13, 2015 | Husqvarna 122HD60 Hedge Trimmer
Broken Tooth for GT90 Hedge Trimmer Gear
I need a manual for UT 31840 18 volt cordless hedge trimmer
Jul 04, 2013 | Dewalt Garden
In need of manual kawasaki hedge cutter
try the piratebay
its a utorrent thing. type in like kawasaki hedge cutter kht600d manual
Mar 13, 2012 | kawasaki Kht600d Gas Hedge Clipper Trimmer
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
Need diagram of blade assembly for Hedge Hog HS 2400 Type 1. Need to know how the spacers and eccentric are laid out between the blades.
try hulufile.com its a good source for pdf manuals on 2 stroke machines. i hope you find this useful as i use them alot ..
Nov 23, 2010 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Echo manuals hard starting hedge trimmer 1500
all echo manuals are available on line at echo.com for free
Nov 01, 2009 | Echo 21.2 CC Shafted Hedge Trimmer
Garden Logo
56 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
