Sansui ld3211 k no display
Its look like the remote control turn on the tv but there is no display at all.
    Top Expert:
  • Televison & ... Master
  • 74,634 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Posted on Aug 03, 2016
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
Code for sansui TV on universal remote control
SAMTRON 0351
SANSUI 0371 1631
SANTECA 0171
SANYO 0001 0801 1051
1161 1261 1531
1581 1911 2871
Sep 19, 2015 | Universal Remote Control Televison & Video
Hi where could I get a sansui flatview 32" remote?
Obviously you could get one from sansui or better yet try ebay they probably will have one it may be a few weeks until one or more show up. Some links to try:
Sansui TV Remote Controls
Sansui Remote eBay
NEW Orion Sansui JVC LED TV Remote Control 076E0TT011 Supplied with models... Replacement Remote for SANSUI HDLCD1909 HDLCD19WB HDLCD1909A
Feb 12, 2015 | Sansui Televison & Video
HOW DO I SWITCH ON MY SANSUI STY1655 LED TV WITHOUT REMOTE CONTROLL
You must have its remote control to switch it ON, if you have switched it OFF by using remote control.
Feb 16, 2013 | Televison & Video
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 25, 2010 | Sansui Televison & Video
Im having problems programing my sansui flat screen tv when i program my rcr311b universal remote it works up untill the point when the tv turns off after pressing the play button and releasing the reverse...
first wat are u trying to do,,,,,,in mind....wat way,,,,,to do wat....try going to get thing that can remote w/remote to do......reverse the plan of mind,,,,
Aug 27, 2010 | RCA RCR311B Remote Control
Code for sansui tv with a RCA 704 remote control
Sansui has connections with the Orion, Akai and Nakamichi brand names.
However according to my information the code you should use for this TV with this particular remote control is 191.
Hope this helps. Please do rate this answer. Thanks.
Sep 02, 2009 | RCA 257003 Remote Control
I need a sansui tv remote control, the one that i
tv.manualsonline.com/.../sansui.../sansui_electric_flat_panel_television_product_list_2.html
u can have a lots of information on tv remote control
Jun 22, 2009 | Televison & Video
Help for Sansui URC-3605 one for all remote control codes. Need T.V code.
try these codes 0000, 1479, 0479 - from our control booklet
Aug 12, 2008 | Televison & Video
CODE RETRIVAL FOR A SANSUI TV MODEL
I lost the remote to my Sansui TV and can't remember the model number. can I get a remote to replace it?, the tv was bought in 2004
Nov 19, 2007 | RCA RCR311B Remote Control
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
