Question about Jenn-Air Dishwashers
Jenn air dishwasher won't start and no lights are coming on
SOURCE: I need a wiring diagram for my Jenn-air dishwasher
I removed the circuit board and reinstalled it.
Now is works fine. Bad connection, I guess.
Posted on Jun 03, 2008
  • 1214 Answers
SOURCE: jenn-air 1250 AWP won't start- lights don't come on
I am going to say it sounds like either bad connections on the controller circuit board, or a failing controller.
I can't find you model on the JennAir site not on SearsPartsDirect, so can't help you much further. If you want to confirm your model number, then I'll look deeper.
Posted on Jan 26, 2009
  • 3230 Answers
SOURCE: Washer will not start
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Good luck.....
Posted on Mar 28, 2009
  • 297 Answers
SOURCE: My Jenn-Air dishwasher has sprung a door leak! :-(
it's just a door gasket,you might still find it a appliance repair place.
Posted on Jul 15, 2009
  • 10865 Answers
SOURCE: Our Jenn Air dishwasher leaks. We notice an
There are two possibilities here. First of all make sure the latch is adjusted to close the door tight. IF not, you can adjust it using a screw driver. next, you may have to replace the gasket as these do wear out.
Posted on Nov 03, 2009
Jenn-air dishwasher will not start
it is usually the panel that fails
Apr 12, 2015 | Jenn-Air Dishwashers
Dishwasher won' t start. None of the lights are coming on
dishwasher wont start. none of the lights are coming on.
Nov 09, 2012 | Jenn-Air 24 in. JDB1080AWS Built-in...
Jenn air dishwasher won't fully drain
Your garbage disposal is clogged . Or your hose from your garbage disposal is flowing in the down position
Oct 22, 2012 | Kenmore Elite 45986 Front Load Washer
Jenn air dishwasher model JDB3610AWX has no power at the control board please help
Their are a couple possiblities that could be causing that;
1) the connections where the house wiring connects to the dishwasher in of the junction box has burnt, the circuit breaker will very likely be on but the bad/burnt connection wont send power to control.
2) one or both of the door switches on the latch asm. are bad,to check those use a meter set to a low ohms setting and check for ZERO ohms when the door is closed,to check those TURN OFF CIRCUIT BREAKER remove wires from switch(s) and place one meter lead on each terminal
I hope this will help you to figure out why your dishwasher won't come on,
Gene
Aug 06, 2011 | Jenn-Air Dishwashers
My Jenn Air dishwasher door won't close. It seems the lower left corner hinge has come (out of alignment), so when you lift the door to close it it stops mid-way like the door is tilted. Not sure how...
Hello sharon. do not use it until this issue is resolved. the hinge may be loose or it may even be bent. get a flash light and check this out. the problem if it is a loose screw is that it may require a special screw driver to tighten the screws again. IF it is under warranty, call for a free repair. Otherwise check it out and see if you can find exactly what the cause is and determine if you have the right screw driver to correct it. Joe
Jul 07, 2011 | Jenn-Air Dishwashers
Dishwasher displaying L# what do I do??
press start and light will not come on and start
jenn-air dishwasher jdb-5
Nov 14, 2010 | Jenn-Air JDB1095AW Built-in Dishwasher
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Jenn-air 1250 AWP won't start- lights don't come on
Jan 26, 2009 | Jenn-Air 24 in. JDB2150AWP Built-in...
Jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Jul 08, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwashers Logo
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
