Question about 3Com Computers & Internet
Ip defoult - 3Com Computers & Internet
My printer does not eject the printed page fully and starts printing the second page over the bottom of the first. How do I rectify this, please?
In your Setings on the print page or setup the print page, press the button Defoult, or Defoult all Setings. That will fix your problem.
Good luck
Oct 20, 2014 | HP Officejet 4500 All-in-One -...
Phone mamory full on nokia N76
Hi There
U might need to use Nokia Suite Pc.Nokia PC Suite is a software program that allows you to manage and move content between any computer and phone that runs a Microsoft Windows operating system. One great feature of this program is that you can backup your phone's data onto it. Whether you just replaced your old Nokia phone with a new one or you just did a factory reset, you can get back your old data and settings quickly if you properly backed them up with Nokia PC Suite.
refer here to backup your phone.
OR U MAY TRY THIS AS SECOND OPTION.
This is a trick for completly format your symbian phones.it specialy usful for those who wants to remove virus from mobile phones. Now here is three methods to format your phone. choose 1 method wich is simple for you..
complete format nokia symbian phones
Important Note:- Before step to this process make sure you have copied all your contacts and notes onto your Memory, because every thing will be deleted. When its finished the formatted phone may be like new, just like when u have brought it from showroom.
This trick works almost all Nokia symbian models. Example n-series,/s60v3, s60v2(N73,N78,N95,N70,N81..etc) and s60 models.
Method 1 hard format
1. Switch off your phone
2. Remove sim card & memory card
3. Now press & hold keys ( 3,*,call green )
4. Then holding these three buttons the press power button
5. Formatting task will be started
6. key *, 3 , call (green) press and hold when display is on than formatting screen is displayed. Wait for formatting to be finished
Method 2
1. Press following key sequence *#7370#
2. It will ask you to confirm press yes
3. Enter Default lock code 12345(defoult by nokia) note <---if you have changed your code type your code not defoult
4. And your phone will be restored in defoult factory setting
Method 3 soft format
1. Press following key sequence *#7780#
3. Enter Default lock code 12345(defoult by nokia) note <---if you have changed your code type your code not defoult.
TQ
Oct 25, 2017 | Nokia Cell Phones
I can't enter the web from 192.168.1.1 or 192.168.1.2 how i can enter web setting AP senao 8610S? what sould i do?
Start>Run>Type in CMD
Press enter
Type ipconfig
Note your gateway
Go to internet explorer and type your gateway in by itself. i.e. 192.168.1.254
Press enter
If this does not work attempt reattempt the gateway address but replace the last number with 254.
i.e. gateway=192.168.2.1 instead type in 192.168.2.254.
Mar 03, 2011 | EnGenius ECB-8610S 802.11a/b/g Wireless...
Can you help me about defoult password of nokLa n97? it is not 1122
Try with this code 12345 or reset is using *#7708#.. good luck.
May 05, 2010 | Nokia N97 Cell Phone
How do you print via computer double side print automatically with duplex on a Ricoh 1232C copier printer.? (also know asc Aficio DSC, Gestetner R032C, Infotec)
First you need to enable the duplex option in the accessories tab.
Go to printers, and sellect properties(right click) and accessories.
Feb 25, 2010 | Ricoh Aficio 1232C Color Copier
UVERSE 2WIRE 802.1 LAPTOP ADAPTER
Try to acquire an address from the router by performing a ipconfig /release command, then ipconfig /renew at the command line. If that doesn't work then you may have to manually enter IP address and DNS address and Default Gateway address in the IP Properties page of your adapter. Could be your present address is using APIPA or Windoze Automatic Private IP Address of 169.254.x.x
Jun 24, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
