Question about Dryers
Location reverse switch
Reverse lights dont come on when i reverse
    Genius:
  • 1,617 Answers
I would need to know the make/model of fan you have!!!!!!
Posted on Oct 21, 2013
Reverse lights
the car comes with 2 transmission.
a/t and m't (auto or stick)
the a/t uses an expensive PRNDL switch (aka. neutral switch)
the m/t uses reverse switch.
both are located on the transmission.
the m/t has 2 wires)
the A./t about 6. (not 2)
with those 2 facts, you can find it, counting wires.
next time post trans type, so we dont have to guess.
Nov 09, 2013 | 2000 Suzuki Esteem
Reverse light will not come on when vehicle is placed in reverse
reversing light switch located on side of transmision box dont think both bulbs would blow at same time also check fuses
Aug 14, 2012 | 1999 Jeep Grand Cherokee Limited
My reverse lights and brake lights dont work on my 97 c1500. the signal work and when i turn on my headlights the tail lights come on but still no brake or reverse lights
It sounds like you have two separate switch problems, brake light switch located at the top of the brake pedal arm, loose or broke, and the back-up light switch located on transmission or linkage depending on transmission type. When asking questions always give as much info as possible.
Mar 15, 2011 | 1997 Chevrolet C1500
My reverse lights are not working. I changed the bulbs already and they still dont work
If the fuses are all good, then you need to try shunting the 2 terminals on the reverse light switch screwed into the side of the transmission.
Feb 01, 2011 | 1993 Toyota Land Cruiser
Where can i find a fuse?
hi the problem is not the fuse its the reverse switch. which is located on top of the gear box. hope this helps.
Mar 01, 2010 | 2000 Ford Focus
Truck go in reverse but tail lights dont come on
possible bad reverse light switch or out of adjustment. located on trans or at point where trans shifter rod or cable hooks to trans.
Nov 07, 2009 | 2004 Dodge Ram 2500
Reverse lights dont work.escort van.1.8 none turbo.2002.
With engine off and key on, emergency brake set, place the gear selector in reverse, using a volt ohm meter check for voltage at bulb terminals. If voltage is present then the switch is working and the wiring to the lamp is good. Next check the other terminal with the ohmmeter to ground for connection. Sounds like a bad ground.
Jul 27, 2009 | 2003 Ford E-Series
2005 hyundai sonata
It is very possible it is the reverse switch that has failed. If you look down between the air filter housing and radiator hoses the reverse switch can be found in the transmission case. The switch has a pink wire that should have 12 volts with the ignition on, and a light green that has 12 volts in reverse only. If the pink wire has power and there is none on the light green in reverse, the switch has failed.
Jun 22, 2009 | 2005 Hyundai Sonata
Reverse lights wont work
On the side of your transmission will be a switch with several wires coming out of it. This is your reverse switch that turns on your reverse lights and most likely needs to be replaced
Mar 15, 2009 | 2003 Pontiac Grand Am
Where is the reverse light switch located on a 2001 chevy caviler,5 speed ,standard shift car
Hi,the reverse light switch is located on top of the left end of the transaxle.It looks like this..Good Luck!!!Dont forget to rate the answer....
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=SMP&MfrPartNumber=LS224&PartType=401&PTSet=A
Aug 13, 2008 | Chevrolet Chevy Cars & Trucks
Dryers Logo
18 people viewed this question
Top Dryers Experts
