Question about Brother MFC 240C All-In-One InkJet Printer
Brother printer mfc 790cw unable to clean error 46
SOURCE: Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Posted on Apr 10, 2008
SOURCE: brother MFC-240c clean unable error
To reset purge counter back to "0" then it will work again.
Posted on Jan 30, 2009
  • 526 Answers
SOURCE: MFC 215C, mfc 215c erorr 46
most likely your flush box is full of ink, the pads will need to be replaced by a service center.
Posted on Apr 20, 2009
pineworks
  • 4041 Answers
SOURCE: Machine Error 46
Hi Error 46.Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
All The Best: Pineworks
Posted on Jan 30, 2010
  • 525 Answers
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Jan 23, 2011
How do I undo unable to clean 46 message
This error is for the Waste Ink Station.
The Waste Ink Station is full. This requires a full dismantle of the machine to clean out and then a reset process run to clear the waste ink counter.
Sep 09, 2014 | Brother MFC-790CW Multifunction Printer
Clean unable 46 my printer is Brother MFC-295CN
printer head not working new head required. call : 09425386687 or email - suvidha_times@yahoo.co.in
Jul 29, 2010 | Brother MFC-440CN InkJet Printer
Unable to clean error 46
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Apr 14, 2010 | Brother MFC 6490CW InkJet Printer
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Unable to clean message
printer brother dcp 115c .unable to clean. what must i do
Jan 19, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
plz search this forum for unable to clean or error 46
it has been explained so many times
Apr 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-215c unable to clean?
@artkoy:
There is no Error 10 within the maintenance of the printer!
An error starting with 10 (and two more digits) belongs to the communication device (fax).
Plz check again what two digit error you have and post again.
@peter:
you need a new waist ink absorber. plz check the forum for unable to clean or error 46. Its explained many times.
Mar 27, 2008 | Brother Multi-Function CenterĀ® MFC-215C...
Brother MFC 240C All-In-One InkJet Printer Logo
54 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
