Question about Samsung HCN5527W 55" Rear Projection Television
Perfect Focus 2
Perfect "FOCUS" is a misnomer.Convergence is the real issue.Enter servicer mode--perform accurate convergence alignment procedure--activate perfect focus as last step to 100% alignment.If you have a High-Definition source,check procedure for that. This is great advice, but, how do I perform all of these steps on my remote? I have a Samsung HCN5527W. Thanks again for your help.
    Genius:
  • 1,694 Answers
Use a site like servicemanuals.com and get the service literature for your make/model.Do NOT perform factory reset procedure-that is reserved for when certain parts are changed.You will need the access sequence,adjust info and add to memory step for servicer convergence.Keep in mind--you may have defective convergence IC's.If so,you will have difficulty w/alignment.Use OEM or better IC's no generics!! They won't hold up.
Posted on Sep 28, 2007
SOURCE:
Green & Blue Ghosting Convergance problem
Odds are real good that the cooling fluid in the green and blue picture tube assemblies has become contaminated. You can tell by looking down into the lenses with a flash light. Funny thing is the red never gets contaminated because whatever organism is causing the problem can't survive in red light. BTW this may still not solve all of your convergence problems but when the colors are so badly diffused the convergence sensors for flash focus can't lock onto the beam landing.
Jun 01, 2009 | Samsung HCL473W 47" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Convergence hitacho 61swx10b
To enter digital convergence adjustment
mode without removing the front speaker
grill, please do the following:
1) Press “Magic Focus” button on the front
panel.
2) While “Magic Focus” is running, press
Magic Focus button again to “Stop”.
3) Press “RECALL” or “STATUS” button after
“STOP” OSD appears on the screen to
enter digital convergence mode.
4) Proceed with convergence adjustment
and save the data.
5) Do MAGICS FOCUS sensor initialization.
6) To exit, press POWER button on the front
panel.
7) Normal and through 1080i modes are
stored separately. Each one has it’s own
memory setting.
Aug 11, 2008 | Philips 60P8342 60" Rear Projection...
Auto focus
you will need a service tech to alien the convergence in the service mode then perform the perfect focus in the service mode to lock this setting in memory.
Jun 21, 2008 | Samsung HCN5527W 55" Rear Projection...
Convergence Problem
Perfect focus in these sets are dependant on factory or service mode calabration. once the unit is calabrated then those setings are stored to be the basis for perfect focus. The fact that you can manual converge the set is a good thing. probaly nothing phycially wrong with your set. However. what is needed is to get a qualified tech to look at your set and to calabrate the convergence.
Mar 04, 2008 | Zenith IQC50H95W 50" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Touch Focus Error
Even if the pix appears to be "OK", the internal convergence
alignment (in servicer mode) must be accurate within certain
parameters for the Touch Focus function to complete w/o error.
Adjustments should be done in "Full" mode,both HD & regular
signal.
Oct 13, 2007 | Toshiba 53H71 53 in. Rear Projection...
White tint/haze
Check any/ all pico fuses in power supply. PVAT! Look for evidence of CRT coolant leak. Since Perfect Focus is a function of convergence,you might consider replacing convergence IC's,then perform alignment in servicer mode,then finish w/Perfect Focus.
Sep 28, 2007 | Samsung HCM4215W 42" Rear Projection...
Perfect Focus
Sep 27, 2007 | Samsung HCN5527W 55" Rear Projection...
Loss of convergence after powering off.
you must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Apr 29, 2007 | Samsung PCN5425R 54" Rear Projection...
Samsung HCN5527W 55" Rear Projection Television Logo
126 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
