Question about Bose Audio Players & Recorders
Bose model 256806-131F or p28/48 home stereo amp phone cord input color codes wire diagram
jyackle5
  • 8197 Answers
SOURCE: Db335 Wiring diagram/color codes
Here you go.
http://www.clarion.com/us/en/MungoBlobs/147/315/DB455MC(Install).pdf
Good Luck and Please Rate FixYa!
Posted on Jan 18, 2009
SOURCE: connecting ipod to bose system
Look at the back of your 3-2-1 to see if the auxillary is a single or dual output. You will need that information when you go to Radio Shack, or you can also get at the Apple store, a connector from Gigaware that connects to the ipod. It was only $15-$20,
Posted on Mar 21, 2009
TwinTurboZ
  • 78 Answers
SOURCE: 2005 chevy silverado stereo wiring diagram
Are you trying to install a new stereo? If so will need to re-wire all your speakers because of the bose system.
And if im not mistaken your year truck might need a really expensive harness to install the radio. Here is a link to it.
http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?tp=3486
You should look into this too! http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?
Posted on May 22, 2009
SOURCE: Apple TV and Bose Home Theater
I had the same problem.
I could not get HDMI to HDMI to work.
i fixed it (work around), by connecting ATV HDMI to DVD HDMI port on V30, i then connect L&R to AUX.  I set the Bose remote for controlling ATV to AUX.
so to use ATV with Bose remote i know press DVD, this gives me the correct display but not audio, i then press AUX and this gives me ATV control and audio.
interesting, when i first set this up (trial and error), it didn't work.  I was doing some cable management clean up, when i got a fright and the thing started working...but i have a ghost in my house so that is probably a more plausible reason why its working now.
it feels like this product is only 90% finished
Posted on May 26, 2009
emissionwiz
  • 80407 Answers
SOURCE: 2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Posted on Jun 19, 2009
Trying to set up Bose 901 series VI to a Nakamichi AV 500 also what gauge speaker wire from amp to speakers
Plain old 18ga lamp cord is fine unless the run is long (over 50', say). Then use 16 ga. Be sure to observe correct phase. Speaker wire is color coded, lamp cord has a ridge on one side. Be sure to always connect the same color or ridge to the same connection (ex: red on amp to copper color wire to red or + on speaker). Do not use "speaker wire" that is smaller than 18go (higher number = smaller).
Jun 25, 2015 | Bose Audio Players & Recorders
2007 Nissan Altima Stereo Wiring Diagram for Bose Navigation
None are actually color coded. The schematic has the wire colors on it next to the wire.
May 01, 2014 | 2007 Nissan Altima 3.5 Sedan
Wiring color code radio
Here is what I show from the manual.
2005 Hummer H2 Car Audio Installation Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Under the Center Console or Behind the Glove Box
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Apr 01, 2014 | 2005 Hummer H2
Sony xplod stereo wiring diagram
Yes you need to turn on the BOSE amplifier in the car to hear the sound. The wiring diagram is actually on top of the factory radio
You will need a 12v trigger to turn the amp on. this is assuming you have all the speaker (inputs) connected to the output from your new deck.
Sep 09, 2013 | 2001 Audi TT
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
Wiring diagram for bose 28060
Infiniti QX56 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Purple
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Green/White
Car Stereo Amplifier Location: To the right of the steering column behind the BCM.
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White/Black
Right Front Speaker Negative Wire (-): Blue/Black
Left Rear Speaker Positive Wire (+): Gray
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Red/Blue
Jul 08, 2012 | Cars & Trucks
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
Blu-ray + bose 3-2-1 system connection?
Connect an HDMI cord from the bluray player to a free input on your HDTV. Then connect the standard WHITE/RED stereo cable from the bluray player into the AUX input in the back of your 3-2-1 system and voila!
You may need to check the configuration of your bluray player to make sure that is outputting stereo audio, for this please refer to the player's user manual. Other than that, you should be alright.
Dec 07, 2008 | Bose 3·2·1 II System
Wiring diagram
See if this link is of any help. I know how crazy these new wire colors can be. I don't know why they don't keep it simple and universal meaning all constant power be red, alt power blue/white, ground black, etc. etc. Even my Hyndai has crazy wires. my red is lf speaker, yellow, lr speaker, etc. Goodluck with it man.
http://64.85.6.118/diagrams/diagrams.asp
May 21, 2008 | Car Audio & Video
108 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
