Question about Vehicle Parts & Accessories
Battery disconnected now the alarm does not work
  • 3,961 Answers
Well, connect the battery again.......sorry, sorry, could not resist.
The alarm has lost its marbles due to being powered off, and has gone to factory default condition. You will need to teach it your own remote code again, and any others used by your family etc
How that is done will be described in the user manual, or, if you don't have one, try to find it on the Net. Of course an auto electrician can do it too.
Posted on Oct 21, 2013
Car alarm preventing car from starting
Try removing the alarm system relay, some car alarm has also a fuse on the alarm that you can remove.
Many car alarms unlock by inserting and turning car key while you connect the battery.
Aug 19, 2008 | 1998 Chrysler Sebring
I have the Audiovox CA425 remote start and keyless entry system and had service done on my vehicle. The door locks and auto start and alarm all worked perfectly. The auto shop disconnected the battery and...
Usually it`s happens with any alarm system when you disconnecting the battery, try to put key in the door and open manually while alarm on, check the fuses
Dec 17, 2013 | Audiovox Vehicle Parts & Accessories
Can i by bypass my car alram
The car alarm on your 2000 Windstar minivan is wired into your van's battery. When you are making a repair to your car such as a battery change out your alarm can go off. You can easily disable the Windstar's car alarm by disconnecting the battery from the alarm. The battery is connected to the Windstar battery's negative terminal. Disconnecting the terminal from the battery will disable the alarm.
  • Socket wrench
  1. 1 Raise the hood of the Windstar to gain access to the battery.
  2. 2 Loosen the negative battery terminal labeled with a "-" with a socket wrench.
  3. 3 Disconnect the terminal from the battery to disable the alarm system.
Dec 12, 2010 | 1999 Ford Windstar
My alarm 'clicker' stopped working - now I have a
Replace clicker batteries leave them out and hit reset internal dot inside clicker !
Jul 28, 2009 | 1995 Pontiac Bonneville
I cannot stop my ford streetka alarm from going off
Locate the fuse and or pwer supply, must be direct of the battery, disconnect either.You said the alarm is replaced in the boot, than the power wire to the alarm is located their.Disconnect it, tape off the end and stow.
Jul 23, 2009 | 2005 Ford Focus
Car wont start
Sounds like you have a shorted wire causing a drain. I recommend disconnecting the alarm all together which should stop the short so battery can remain fully charged.
Jul 09, 2009 | Hyundai Motor 2002 Sonata
ELANTRA ALARM PROBLEM
If the alarm keeps going off constantly and the remote has no influence on the alarm its most likely a connection problem. A hyundai dealer might be able to fix it but since you can start the car something you might be able to try is....
Check and make sure the remote battery is in the right way. Make sure all of the doors are closed, the trunk is closed, open the hood, connect the battery, close the hood all the way and try to lock and unlock the doors. Hope this works but if not, sorry it didn't work.
Jul 04, 2009 | 2001 Hyundai XG300
Car alarm won't reset after disconnecting car battery
you should try to hit the unlock button on the remotes and that should disarm it. Try disarming that, that way and if that doesnt work we will go from there
Feb 22, 2009 | Vehicle Parts & Accessories
I am having trouble also but I need to know how to disconnect the alarm. I would appreciate it if you could help me out seeing that you have disconnected yours. Thank you
Jul 12, 2008 | 1998 Chrysler Sebring
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
