Question about Vehicle Parts & Accessories
I have removed the battery on my car now the alarm does not work
  • 489 Answers
No alarm system in the Smart car , just security system
Posted on Oct 22, 2013
I replaced the battery in my 2008 Chevrolet Colorado and the factory alarm aka my horn won't stop going off. How do I reset my alarm?
pull the horn relay till its sorted
factory alarm may need a diagnostic scanner
might be a faulty module
Apr 16, 2017 | Chevrolet Cars & Trucks
Car alarm preventing car from starting
Try removing the alarm system relay, some car alarm has also a fuse on the alarm that you can remove.
Many car alarms unlock by inserting and turning car key while you connect the battery.
Aug 19, 2008 | 1998 Chrysler Sebring
Cobra troubleshooting
We do not have info on aftermarket systems. Suggest you remove it completely and install a quality system.
Dec 31, 2013 | Cars & Trucks
Ca5050 uninstall
If you didn't remove the alarm "brains" under the ignition, your car is still being protected by the alarm. It is acting as a cut-off switch and will not let the car start. This can be resolved by taking the wiring and alarm relay with brains out. To do this look under steering column for the wires that are comming from the ignition, then which wire is going to your alarm light. That is the wire or wires that need to be removed and rewire the direct wires for ignition. Be sure to get all alarm system wires and components under dash out. From there you just wire the original wiring back together and should start car. If not, make sure your battery is not dead. The alarm can drain car battery if a relay is not working.
Sep 02, 2012 | Cars & Trucks
How to disconnect viper car alarm
Find your alarm module, it is a black, rectangular box with an antenna wire on one end. Remove any ties or fasteners holding the alarm in place and take it out from under the dash.
All you need to do is simply remove the two connected wires to the ignition switch, and connect it with the car side of the two together. This enables the ignition switch and that enhances the control over the starter again, without hindrance.
For further help and assistance contact Eurobahn BMW MINI Mercedes-Benz Audi of Greensboro.
Jun 10, 2017 | Viper Vehicle Parts & Accessories
I have a car that has a theft buster alarm that was installed before I purchased it. Now it decides when It will work and when it won't. I dont use the alarm, The car won't start and the battery looses...
Any Stereo Shop can remove the alarm for you.
The alarm module will be mounted under the dash.
Unplugging the harness from the alarm will solve your problems.
Nov 16, 2010 | Chevrolet Malibu Cars & Trucks
Remove car alarm in 1998 ford escort?
Unfortunately i wish it were easy to remove the alarm system, but then, so does every car thief in the world.you cannot remove the anti theft system in any car,contrary to whatever someone may say.the brain is embedded in the cars electronic management systems.but you can remove the fuse......
Mar 10, 2010 | 1998 Ford Escort
2001 mercury cougar can't get car to start alarm light lit and steady what do I do
sounds like your alarm is preventing the car from starting.
you can disconnect your negative battery cable, and wait about 10 minutes. put the key in the ignition and turn it to the ON position, but NOT to the START position. reconnet the battery cable CAREFULLY with the key ON, and the driver's side door OPEN. your alarm should "chirp" a few times, while reconnecting the battery. afterwards, try to start the car when the battery is tightly connected.
if the car still refuses to start, use the "panic" feature on your remote, to intentionally set off your alarm, and then turn it back off, to make sure it stops properly.
if this does not work, remove the fuse for your alarm, and try to start the car again without the fuse in place.....otherwise replace the fise and remove the pwoer connector from your alarm.
your actual alarm should be behind the trim plate, on the bottom side of your dash, above your gas and brake pedals....then try to start the car AGAIN....
if none of this works, then your alarm is defective and needs to be serviced be the installer, or manufacturer. also, calling the manufacturer will help too, as they have "reset and disable" features that can literally "bypass" your alarm.
Oct 03, 2009 | 2001 Mercury Cougar
Car wont start but the alarm goes on and it never used too
try removing the battery + for at least 2 minutes. it should reset the alarm system. if it doesnt work you need to make your remote work try replacing the batteries and try it
May 30, 2009 | 1990 Mitsubishi Eclipse
Alarm system not working
A friend of ours did some research and discovered it was the ECU (fuse?) that needed to be reset. We removed the ECU (which controls the cruise control, and "learns" the driving patterns of the driver and adjusts the fuel economy) and the car is running fine. To reset the ECU you need to remove the negative cable from the battery, turn the car to "A/C On" (don't crank the engine) for 10 seconds, then shut it off. Replace the negative battery cable. This should reset the ECU. The car does run much better with the new battery. The previous battery was the original and was approximately 6 1/2 years old so it needed to replaced anyway.
Nov 09, 2008 | Hyundai Motor 2002 Elantra
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
