Question about BenQ MP510 DLP Projector
BENQ MP510 POWER PROBLEM SOLUTION - BenQ MP510 DLP Projector
I have a BenQ proyector model mp510 wich lamp doesnt start, I would like to Know how to check the lamp or how determine or find another problem.
best bet is speaking to BenQ direct - or at least where you bought bulb from and get them to take a look - does the bulb look ok or have you been unlucky and got broken bulb still?
if you can't get on, then can't see menu which means youre stuck.
sorry
good luch
Jan 28, 2013 | BENQ MP510 Original bare projector lamp...
I have a vivitek projector which produces white and black horizontal lines through the image. The menu will not display and neither will any input. What exactly is the problem? I have tried...
I've got the same problem with my NEC LT75Z DLP projector.
I am currently trying to fault find the unit, but need extender cables and special plugs and sockets to achieve this.
It will most likely be a partial power supply fault or a processor board fault, since the lamp comes on and the leds and fans operate, and the colour wheel spins correctly.
Jun 18, 2011 | BenQ MP510 DLP Projector
How can I connect BENQ MP510 multimedia projector with Acer Aspire one D255E notebook using windows 7? Do I need installation of extra driver for that?
Hi!
No you don't need a driver, connect it using a VGA Cable, then press FN Key at the same time with Fkeys that has a monitor screen Icon on your keyboard.
Hope this helps.
Mar 17, 2011 | BenQ MP510 DLP Projector
How do you reset the projector after lamp installation?
Its a pretty simple process on this particular model make sure the new lamp has been installed properly, and the power to the projector is on and then:
i. Press and hold the Up Arrow on the projector for 5 seconds to display the total used lamp time.
ii. Press AUTO on the projector or on the remote control to reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
That should take care of it...
CANON PIXMA MP510 WILL NOT POWER ON
I had a similar problem. What worked for me was to remove the power pack, which is secured by two clips. Slide a knife or similar to release the power pack. It will slide out to reveal a mini-plug with five red wires. Disconnect this.
This where it gets a bit uncertain. I plugged in the power pack and put a meter across the outputs. They seemed to be working (ie I was getting voltage). I had a quick look at the indide of the MP510 and decided there was nothing further I could do. I then reassembled everything and, just out of curiosity, pressed the power button again. And it came back to life!
I suspect that in your and my cases, the MP510 had "crashed" and I performed a hard reset by removing and then reconnecting the power pack. But who knows? Best of luck
Nov 07, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Benq mp610
I replaced my lamp on my Projector MP510 after the projector shut down. I followed the instructions in the book to reset the projector but the projector shuts down all the time. Please can you help me HARRY
Sep 14, 2008 | BenQ MP610 Multimedia Projector
BenQ MP510 DLP Projector Logo
27 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
