Question about Jenn-Air JCB2285KES (21.5 cu. ft.) Side by Side Refrigerator
Jenn-air refrigerator too cold - Jenn-Air JCB2285KES (21.5 cu. ft.) Side by Side Refrigerator
  • 146 Answers
What are your temp control settings frrzer should be about zero and fridge side should be around 39 degrees temp. try setting it lower maybe 3 if control knob if digital check for 39 to 40.
Posted on Dec 08, 2013
4 Suggested Answers
  • 360 Answers
SOURCE: How do I level a Jenn-Air side by side refrigerator
this manual has leveling instructions in it, to download, click --->here<---
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 16, 2009
  • 72 Answers
SOURCE: Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Posted on Jun 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jul 13, 2010
Jenn-Air side by side refrigerator, Model JRSD2490. Not staying cold enough
Larger=colder. Make sure that 1) your magnetic strip around the fridge door is sealing well. Even a small leaking area could make it difficult to keep cold, especially in warmer areas. Also, make sure there is nothing obstructing the door from closing completely and sealing properly. I had this same issue where one of the door shelves was unlatched a little and the door would close but not seal. Beyond that could be motor or more likely compressor or coolant leak. Good luck.
Jun 20, 2014 | Jenn-Air JCD2389G Side by Side...
Freezer working but no cold air to refrig.
check the damper vent door located behind a plastic cover between the freezer and refrige compartments,also make sure the evaporator fan is operating to blow cold air through this door,if the door isnt open,then either its frozen shut due to moisture or the motor that controls it is bad
May 13, 2011 | Jenn-Air Jenn Air Side-By-Side...
My jenn-air french door refrig is not getting cold
When the refrigerator is not cooling but the freezer compartment is cold, this is usually the result of a defrost problem.
http://refrigeratorheaterrepair.blogspot.com/
Dec 28, 2010 | Jenn-Air JFC2089HE French Door...
I have a jenn-air jcd2389ges that is not getting cold.it runs and works but is not getting cold ..
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
May 20, 2010 | Jenn-Air JCD2389G Side by Side...
I have a jenn air side by side. the freezer is
This is usually a sign of a defrost problem. I will need you model number to help you better. Sea Breeze
Jun 26, 2009 | Jenn-Air Refrigerators
Jenn-Air JCB2285KES (21.5 cu. ft.) Side by Side Refrigerator Logo
85 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
