Question about Bosch Drills
The drill end will not alter to hold the drill bit
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: TE 6-C Hilti Hammer Drill.
Go to this LINK.
Post or thumbs back!
Posted on Nov 04, 2010
Capillary tube
You can determine this by taking a numbered drill bit index and inserting the proper size diameter but end of the bit into the cap tube. You can then mic the butt end or cross reference to chart giving size of numbered drill bits. The length is also very important when sizing, cap tubes must be as close to exact length as possible. Also cap tubes must be scored with 3 corner file and broken off so as not to alter inside diameter.
Or you could use a cap tube chart. Try www.supco.com
Apply Freon type, compressor HP, temp range of unit, number of feeds.
Aug 24, 2013 | KitchenAid Refrigerators
I have the drill, I have the bits...there is something missing to connect both. What does it look like?
Although you posted your question under Chainsaws instead of another tool forum, look at the end of the drill. Is there a hole surrounded by a cone shaped metal end? This is the chock, if you spin/turn it counterclockwise, the opening should widen to accommodate the drill bits, then spin/turn it clockwise to tighten/clamp down on the drill bit. Some drills accomplish this with an l-shaped key that has a small cone-shaped gear on the end that fits into holes on the chock. Some drills have a chockless drill, and you simply hold the end of the drill and squeeze the trigger to use power to tighten/loosen the bit.
Aug 31, 2011 | Garden
Have never used a hand dill, how do i change the drill bit. i need to drill a small hole. thank you anne
Typically, the end of the drill where the bit is inserted (called the 'chuck') rotates to loosen or tighten the arms holding the bit in place. Grasp the top of the drill with one hand and rotate the end the bit is inserted into counter-clockwise if the bit end is pointed towards you to loosen the arms and release the bit.
If it is an older drill it may have a 'key' that would look similar to end of a phillips screwdriver on a tee that can be inserted into where the chuck and the rest of the drill assembly meet and twisted to loosen the bit.
If neither of these work post what type of drill you are using as not all hand drills are the same. Hope this helps.
Dec 10, 2010 | Garden
Putting new bit in my skil9. I'm relatively new with my drill and i'm trying to hang curtains so I need a bigger bit in my drill
Hold the black part on the end of the drill with you hand firmly and then run the drill in reverse...that will loosen the bit...
Place the next bit into the drill and then holding the end run the drill forward till the bit is tight...
heatman101
Dec 05, 2010 | Skil 2566 02 120V 14.4V Cordless Drill Usa
Hilti te 10 - how do I change the bit ? and lock it good...
The end of the drill is 2 parts hold the bottom part(closes to the drill) and turn the top part (the end the bits in) and turn it a 1/4 turn counter clockwise that opens the chuck then pull the bit out to replace do the opposite. Don't let the end at the drill spin or it will come off the drill completely if that happens simply line it back up and tap it hard to get it back on
Nov 25, 2010 | Hilti Hammer Drill Bit TECX 1 In x 10 In...
How do I change a bit
This drill uses a keyless chuck. which means you have to hold onto the barrel by the end of the drill chuck. Then you need to put the drill in reverse to open the chuck to put a bit in. Insert a bit and then put the drill back into forward and hold chuck to tighten.
Nov 14, 2010 | Milwaukee Tool Milwaukee 0824 24 v18...
Drill chuck is frozen
You may try to put a thick soft metal pipe (aluminium or copper) over the drill bit (longer than the bit itself by ~10 mm) so it will touch the chuck's jaws, then GENTLY hit the other end of the pipe with a hammer several times, holding the pipe a bit askew, thus trying to disengage the jaws from the lock in their thread, and try to loosen the chuck after each series of hits. Just be careful with your fingers, and better hold the drill by the chuck while hammering it - so the hits won't go to the transmission unit (sorry for description - hope it's understandable, if not - ask for clafication from me)
Apr 26, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do you change the drill bit for a Ryobi?
My husband explained this, via phone ..... made it simple....... grab the silver ring area beneath the black top area where the drill bit is located. Hold the silver area firmly, while you twist the black top. You will see the release, then remove drill bit. Laymen's terms, but it worked!!
Mar 16, 2009 | Ryobi 18v Variable Speed Impact Driver...
Hitachi Quick Release Drill problem
put a box end wrench 7/16 or a 3/8 over the bit. put the bit in a vise. Lightly tap the wrench with a hammer while holding the relase sleeve back. usually need 2 people. 1 to hold the drill and the sleeve and 1 to hold the wrench and hammer. try a little tranny fluid or wd40 in the chuck. don't use the painted bits. use onle the chrome ones
Sep 30, 2008 | Drills
Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
29 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
