Canon ir 5000 error e000001-0003 - Office Equipment & Supplies
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
  • 3 Answers
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Posted on Jun 04, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
  • 7 Answers
SOURCE: My canon 5000 ir 6000
change the
hdd that compatible to your machine
Posted on Oct 04, 2010
  • 7 Answers
SOURCE: canon ir 5000 error code
change the hdd,,
ERROR CODE E000350 001...
This is a fuser/thermistor error. You may have to get it serviced, but try to reset the error code using the following:
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Apr 20, 2015 | Canon imageRUNNER 5000 Copier
Error 003 in canon IR 5000
A E003 is a error code with the fixing unit. I would first try to reset the error code in service mode first. If that will not correct the problem, most likely the thermistor will need to be replace. The PCB connection break off. I would replace the sub thermistor at the same time. Good Luck
Dec 23, 2012 | Canon imageRUNNER 5000 Copier
Eror e00014 pada ir 5000, sudah dierror *28* tetapi tetap masih eror. motor pemanas tetap gak jalan gimana yaaaa? tolong dong solusinya...
bos tolong nih, kode error E00004-0010 pada mesin canon ir 6570, gimana solusinya. terimakasih sebelumnya
Mar 17, 2011 | Canon imageRUNNER 5000 Copier
Sisa toner di sekitar cleaning blade mesin canon ir 5000 mengeras apa penyebab dan solusinya
bagaimana cara mengatasi kode error 804 pada canon ir5000, lampu scanner kedip-kedip pada saat mesin start.
Nov 21, 2010 | Canon imageRUNNER 5000 Copier
Error Message E000001-0000
its a fuser error high temp or lower temp
try to rest this error in *28* FUNCTION,CLEAR,ERROR then on off the machine
if the error the same try to replace tem sensor
Oct 28, 2009 | Canon imageRUNNER 5000 Copier
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Dec 25, 2008 | Canon imageRUNNER 5000 Copier
93 people viewed this question
k24674
jasbo
jasbo
