Question about Konica Minolta bizhub 350 All-In-One Laser Printer
C-3571 error - Konica Minolta bizhub 350 All-In-One Laser Printer
My 6th sense a+a 7 kg awo 3571 8 year old washer doesn't seem to be adding enough water to wash or rince . Clothes have a strong smell of detergent
You should open machine from the bottom and unscrew the draining pipe that comes from the drum. In there there is a plastic ball. Take it out and put machine back together (clean draining pipe and hole in the drum where it comes together or it will leak). That ball is there to prevents spill outs in case of doom, but in practice threw time like 7-8 years it gets clogged and prevents pump to dry drum properly (can also burn your pump ergo new machine).
Now clean drum around the entrance and detergent dispenser with strong detergent (you can take product specially designed for mold or just use bleach) and after wash it on 90°C long program.
Change detergent as it may be bad quality. Try to use liquid one.
If problem persist it may be quantity of water. You can change quantity threw software (look it up and increase it, if it's set too low) (check manuals on that).
There may be human error, if you use programs that are short and cool or if you let your cloth seat in the drum after it's finish or if you add to much of detergent. You may get these results as well.
Mar 30, 2016 | Washing Machines
F05 fault after replacing brushes
F05 - NTC failure (SC/OC)
All appliances managed by the electronics measure the temperature using a thermistors. These thermistors changes resistance depending on the temperature. There are two kinds of thermistors, NTC and PTC.
NTC has a negative temperature coefficient which means that with increasing temperature the resistance decreasing (used in washing machine, dishwasher, dryer, refrigerator....etc).
PTC has a positive temperature coefficient which means that with increasing temperature the resistance increasing (used in oven, refrigerator for starting compressor...etc).
If you look in the table below, it is clear that the resistance value of 100 ohm means that is NTC faulty. So, I really do not understand how it is possible that the resistance increases with temperature?
Resistance of NTC depending on temperature
0 °C 35.9 kohm
30 °C 9.8 kohm
40 °C 6.6 kohm
50 °C 4.6 kohm
60 °C 3.2 kohm
70 °C 2.3 kohm
95 °C 1.1 kohm
Dado
Jul 16, 2015 | Whirlpool Washing Machines
I want serial key for Adobe Fireworks CS5
Use this serial for your Adobe Fireworks CS5:
Serial: 1193-1900-0856-9275-8211-5090
Feb 18, 2011 | Adobe Fireworks CS5 Windows for PC...
The drum of my washing machine (a Whirlpool AWD 3571) has started to make a loud noise when it turns - both manually when machine empty and during a wash. How can I fix this?
makes a loud noise most when spinning comes from rear bearing either about to let go or has let go but not completely this is a job most technicains love to do because they charge more then the machine is worth to fix it although it is time consuming some can do the job in about 3-4 hrs with properly lubricating and cleaning and reinstalling the new parts you have to consider the hole inside of the machine has to come out and then the wash drum has to be taken apart down to its smallest components and then put back together usually ive seen them charge between 4-650 dollars in my opinion its much cheaper to just go out and treat yourslef to a new washer to assure that it is the rear bearing remove the top cover youll see the drum when you do have some one spin the drum while you listen towards the back of the machine have them spin it by hand by the way if you are hearing the noise when they spin it by hand and its toward the rear then you need a new rear main seal sorry about the bad news if i can answer any further questions please message me back please also remember to rank how this opinion has helped in your appliance situationThanks again
Rick
Dec 10, 2010 | Washing Machines
Need a NCK code to unlock a sony ericsson c902
download aerix programme this for unlocking sony ericsson mobiles easy to use and free
May 28, 2010 | Sony Ericsson Cyber-shot C902 Cellular...
Need a drawing of the worm shaft and spool valve assy.
closest I have is 94 explorer. may be similar.
Item Part Number Description 1 3E501 Steering Gear Sector Shaft Seal 2 3524 Steering Gear Input Worm Gear and Rack 3 3647 Steering Gear Worm Ball 4 3523 Steering Gear Ball Return Guide 5 3A670 Steering Gear Worm Thrust Bearing Adjuster 6 — Locknut (Part of 3577) 7 3571 Steering Gear Worm Thrust Bearing 8 3575 Steering Gear Sector Shaft 9 3524 Steering Gear Input Worm Gear and Rack
May 09, 2009 | 1983 Ford F 250
Uk sony ericsson w660i
do as follows.
  1. Remove the SIM card from your phone
  2. Turn the handset on
  3. Press the LEFT ARROW one time
  4. Press the * button 2 times
  5. Press the LEFT ARROW one time
  6. If you have entered these directions precisely, you will see the message PERSONALIZE under that NETWORK select it then select the option MNC2
  7. Type in the unlocking code that was sent to you and PRESS ENTER
  8. Your phone will be unlocked
hope this will help you.
Mar 25, 2009 | Sony Ericsson W660i Mobile Phone
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
