Question about Research In Motion Blackberry Bold 9790 8gb Internal 5mp Phone Blackbundled 4gifts1 Year Warranty
Fix memory card slot
My memory card slot is malfunctioning; it will not read my memory card. But I have tried it in other phones and it works but not on mine. please help.
    Problem Solver:
  • 6 Answers
Does it read it on computer when you hook it up? clean outthe small compartment with air in a can
Posted on Oct 25, 2013
Not reading memory card
SWITCH OFF THE PHONE
REMOVE THE MEMORY CARD FROM ITS SLOT
PUT THE MEMORY CARD IN ITS SLOT AGAIN SLOWLY AND STEADILY
SWITCH ON THE PHONE NOW WAIT FEW SECONDS IF IT WORKS AFTER SOME TRY'S THEN GREAT OR JUST FORMAT THE MEMORY CARD
Apr 12, 2014 | Samsung Corby 2 GT S3850
In my sony ericssion phone w350i when i insert
This error may be of hardware or software... If the hardware in nature then you have to get it serviced.....
But before servicing try out following..... (1) insert your memory card in another cell and check that, that cell can read the your card... If another cellphone read your card means.. your cell's memory slot has malfunctioning.. So get it serviced.....
(2) or you can insert another memory card in your cell.. If this new card is read by your cell that means, your current memory card has been corrupted,... so buy a new memory card.....
(3) If the above both options fails.. then.. There is a also rare possibility of software corruption.... to update your software visit to the given link.... http://www.fixya.com/support/r4622711-updating_sony_ericsson_s_software_free
Hope this has helped you... Please rate the answer... Thanks....
Jul 02, 2010 | Computers & Internet
Memory card is not working
The reason the memory card is not working could be either the memory card is not working or the phone is not reading the memory card.
To test if it is the memory card,
insert the same memory card into another phone to see if the phone reads it.
if it does not read it, then the fault is from the memory card.
all you have to do is to replace the memory card.
To test if it is the phones memory card slot,
install a tested okay memory card into the phone to see if it will read it.
if it does not read it. then it is the phone. it could be a software problem or a hardware problem.
firs flash the phone with the appropriate software to see if it will work, if it does not, then it is the memory card slot.
To change the memory card slot,
follow these steps,
  1. First remove the battery cover & battery. Remove the two screws you see.
  2. Run your fingernail around the join of the front cover and then remove the front cover.
  3. Now remove the four screws you can see.
  4. The top part of the phone (PCB and LCD screen) can now be removed from the middle chassis.
  5. then you will have access to the memory card slot,
  6. remove it and carefully install a new one,
  7. reverse the process to reassemble the phone back,
  8. test it with a memory card.
take care
Jun 19, 2010 | Nokia 6300 Cellular Phone
5800 MMC NOT WORKING
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
Jun 18, 2010 | Nokia 5800 XpressMusic Smartphone
When i put my sd card in the computer to download pics, my computer is not recognize it, what can i do to fix it
If the phone refuses to read the memory card, it is due to the fact that, the format of the memory card is not supported by the laptop.
In order for you to read the files of the memory card on the laptop, try to use a memory card external slot that uses the usb cable to connect to the laptop.
You can fix the memory card into phone,and connect the phone the computer through the usb cable.
Read the files through the phone and you will be able todownload your pictures.
Take care
Jun 17, 2010 | HP Pavilion dv6000z Notebook
Continues to tell me to insert it when it's there
The reason the phone is not reading the memory card is either the phones memory card slot is faulty or the memory card is not in good conditions.
To test if it is the phone, try a well tested memory card in the phone to see if it reads it, if it does not then it is the memory card slot.
to solve that, try to open the phone and clean with spirit and drey it with the heat from a bulb, or you can replace the slot.
To test if it is the memory card, try the memory card another phone that the memory card is working fine.
if it does not read the memory card, then the fault is from the memory card, and the solution is simply to replace the memory card.
Make sure the memory card is not above 16GB.
Take care
Jun 14, 2010 | Samsung SCH-U450 Cell Phone
My nokia 6600 does not read the memory card thought i have a brand new memory card inserted on the memory card slot.
The new memory card you bought might not be compatibility with the phone or may be you didn't fix it properly that's why it's not displaying..
Take your memory card to any of your friends that has similar memory card slot or phone as yours and see if will function .
Feb 17, 2010 | Nokia 6600
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
I have problem with my memory stick in w850
It should be a problem with your memory card slot in your phone. It could solved by dusting the inside of your memory card slot.
After trying this, please reply whether it worked.
Thank You
Nov 15, 2008 | Sony Ericsson W850i Cellular Phone
Research In Motion Blackberry Bold 9790 8gb Internal 5mp Phone Blackbundled 4gifts1 Year Warranty Logo
26 people viewed this question
Top Research In Motion Cameras Experts
Mark Schmit
Mark Schmit
cwradio73
Ankit Tiwari
Ankit Tiwari
Level 1 Expert
Are you a Research In Motion Camera Expert? Answer questions, earn points and help others
