Question about Marshall Electronics VS-TKC-100 PTZ Keyboard Controller -
Driver VS-TKC-100 - PTZ Keyboard Controller - Marshall Electronics VS-TKC-100 PTZ Keyboard Controller -
PTA cameras wandering on their own
check if the Auto Pan setting is enabeld. if not the joystick on your PTZ Controller might be faulty. open the unit up and check for any dust build up on the joystick area.
Aug 26, 2013 | Pelco KBD960 Full-Functionality, Desktop...
Tip
Unlockable Characters
Ness- Reflect ten projectiles in battle or play 5 vs matches
Marth-Beat classic mode or play 10 vs matches
Luigi-Beat classic without using any continues or play 22 vs matches
Falco-Beat 100 man brawl or play 50 vs matches
Captain Falcon- Beat classic mode in less than twelve minutes or play 50 vs matches
Lucario- Beat him in adventure mode with Meta Knight, beat five target tests or play 100 vs matches
Snake-Play 15 matches on Shadow Moses island or play 130 vs matches
ROB-Get 250 different trophies or play 160 vs matches
Ganondorf-Beat classic or hard with Link or Zelda or play 200 vs matches
Mr. Game and Watch-Beat target smash with 30 players or play 250 vs matches
Sonic-Beat classic with ten characters, play for ten hours or play 300 vs matches
Jigglypuff –Beat event match #20 or play 350 vs matches
Toon Link- Beat Subspace Emissary than classic with any character or play 400 vs matches
Wolf-Beat Subspace Emissary than boss battle with Fox or Falco or play 450 vs matches
Zero Suit Samus- Hold R on a Gamecube controller or minus on a Wii controller while selecting Samus.
Sorry everything is underlined, something is wrong with my computer
on May 19, 2010 | Nintendo Super Smash Bros. Brawl for Wii
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
Spin out of control
Reset the power to the camera and test first.
If it worked before you may have a wiring fault... or if it is new or someone tampered with it, the baud rate settings or protocol setting might have changed.
Apr 03, 2012 | Pelco CONTROLLER MATRIX- PTZ CONTROL
I can't remove numbers that appears in screen when i use a Samsung PTZ camera. Can you help me?
sounds like you are seeing a display generated from the PTZ camera itself. can you access the camera's menu?
Jul 20, 2009 | Samsung SADT-100PM POLE MOUNT ADAPTER FOR...
Audio drivers needed for my pc. plz help.
Sound card driver for
Realtek AC97 Audio CODECs Driver v4.06 Windows 98SE/ME/2000/XP/2003(x32/x64)
http://www.opendrivers.com/driver/286655/realtek-ac97-audio-codecs-driver-v4.06-windows-98se-me-2000-xp-2003(x32-x64)-free-download.html
Mar 23, 2009 | Computers & Internet
What is network controller in ''other'' devices
I don't really think that your keyboard has anything to do with your network controller. I'd suggest to update the keyboard driver to a newer version if there is one. Can you tell me the model number and the brand of keyboard?
Feb 24, 2009 | Dell Computers & Internet
Broadcom 440x 10/100 Integrated Controller driver will not load
Your resolution will most likely be a replacement of the motherboard. You can try flashing the BIOS and see if that resolves, but from your details it appears there is a hardware failure of the motherboard. Generally, you can find a motherboard for this model on Ebay for around $100
Jan 10, 2009 | Dell Inspiron 8600 Notebook
EHCI controller not detected
try installing the software drivers for keyboard and mouse.....then see whether keyboard and mouse is working...if the problem persists.....then the problem is in motherboard.....that you have to give it to repair shop....so that you can identify the problem.....i am a software engineer.....and i have experience in these areas....thats why suggesting you this idea....try this....it will work 100%.....
Sep 20, 2008 | ASUS P5SD2-X Motherboard
Installing a pelco ptz camera using my old controller
pelco cctv ptz doec not moving can you give me a solution?thanks a lot.
Aug 18, 2008 | Cameras
Marshall Electronics VS-TKC-100 PTZ Keyboard Controller - Logo
85 people viewed this question
Top Marshall Electronics Video Cameras Experts
Are you a Marshall Electronics Video Camera Expert? Answer questions, earn points and help others
