Panasonic CT27HL14J sound but no video
I have a Panasonic CT27HL14J that worked fine yesterday. I turned it off and went to sleep and woke up this morning with sound but no video. I can't get the menu. I switched through each video channel and nothing. Please help
  • T2XXXXX Jan 26, 2008
    I have the same problem. Did you get yours fifed? If so, what was the problem?
  • mightymort42 May 01, 2009
    have sound but no picture
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As sound is present but no video it is due to loose contact in connector or print. if it is ok than there must be oroblem in ckt. 1 crt base loose. 2 supply to video &signal processor absent. 3 components in video section. 4 voltage on crt base not proper like g2 & filament. remember it is not major problem. hope this will help good luck.
Posted on Sep 30, 2007
SOURCE:
I just bought these side swipe ihip Bluetooth headphones. I was using them fine last night. I turned it off, went to sleep, woke up and now they don't want to turn on. I connected it to the charger and the...
I sounds like the battery has failed and will no longer hold a charge. Generally, the batteries are not replaceable.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 20, 2014 | Cell Phones
Is ther a fuel cutoff switch for my 1994 bmw 325i
No fuel and no spark sounds like a bad fuse.
Apr 12, 2012 | 1994 BMW 3 Series
Yesterday my 89 Mercury Grand Marquis started up but sounded different, i figured something was up, but it ran fine. throughout the day after turning it off to go into a building an returning to my car it...
may be your alternator is gone, when the car is running the battery is out and the alternator takes over, so is got to be your alternator, try to restart your car and if it runs disconect the negative cable from your battery if the car dies the alternator is bad.
Feb 25, 2011 | 1989 Mercury Grand Marquis
Black screen and no sound after a few minutes.
First, here is a copy of your manual in case it is missing.
http://www.warrantyweek.com/library/ww20061219/panasonic-th42px60u-manual.pdf
Next, check the settings of the sleep timer.
Select on the remote:
Menu.
Timer.
Sleep.
See if there is a time setting in there. You may also find a shortcut from the remote labeled "Sleep".
If this fails to resolve the issue, you can always reset to factory defaults. To do this, select from the remote:
Menu.
Setup.
Reset.
Hope this helps. Be sure to let us know how this helped.
Jun 30, 2010 | Panasonic TH-42PX60U Television
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
The sound button on my keyboard doesn't work
Well, reinstalling the drivers would have been my first bet...If you use volume control on your keyboard a lot, maybe pop off the key and check under for dirt/grime?
Oct 16, 2009 | Sony VAIO VGC-JS230J/S PC Desktop
My voyager keeps turning off
my phone was doing the sam,e you have to go to verizon and they will tighten a screw inside then it all works again =)
May 05, 2009 | LG VOYAGER VX10000 Cellular Phone
Player won't turn on
Loud noise = diode is bad, and the dvd player needs to be repaired/replaced
Jun 16, 2007 | Toshiba SD-K740 DVD Player
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
Ekse
